EGR nightmare - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 03-28-2014, 08:02 PM Thread Starter
Garage
EGR nightmare
I have posted up once already regarding my EGR throwing codes. This time it is all over the place, I pulled a p0401; EGRflow insufficient, p0404; EGR curcuit range, p1335; EGR position sensor, p1102; MAF sensor in range, but lower then expected and p0113; IAT sensor curcuit 1 high.
The last time I pulled the p0401 I changed my EGR valve and it was fine for a short time. I pulled the codes after I decided to "drive it like I stole it".
What it the next course of action?
1ststroker is offline
post #2 of 17 (permalink) Old 03-28-2014, 08:34 PM
matthewd11's Avatar
Re: EGR nightmare
delete it or turn it off
matthewd11 is offline
post #3 of 17 (permalink) Old 03-28-2014, 08:42 PM Thread Starter
Garage
Re: EGR nightmare
I have the bulletproof cooler already
post #4 of 17 (permalink) Old 03-28-2014, 08:50 PM
Happy Camper's Avatar
Re: EGR nightmare
I'm a 6.4 guy, but I think I would 1st contact bulletproof since you bought their stuff and put it on, and if you get nowhere with that, then I would delete it, and sell the cooler on eBay. Cut your losses and save the engine while you can!
2009 F250 Lariat CCSB 4X2
Flo-Pro 4" CAT/DPF Delete
Rudy's EGR Delete
Rudy's Stainless Up Pipes
S&B CAI
SCT Livewire TS 5015
170K and counting...
XD(M) 40 S&W
Happy Camper is offline
post #5 of 17 (permalink) Old 03-28-2014, 10:15 PM Thread Starter
Garage
Re: EGR nightmare
Just to clarify this, the EGR cooler was installed 2 years ago with no issues. The most recent issue was mulitple issues, EGR valve and FICM (p0611).
I spoke with bulletproof about the recent issues and what I have done. His thoughts are with the amount of codes pointing to different items that it is probably wiring. I checked the batteries with and without a load, they are good. His recommendation was to go back to square one with what was done last week and check the connections and the overall condition of the wires.
post #6 of 17 (permalink) Old 03-28-2014, 10:32 PM
Re: EGR nightmare
egr delete is the true fix! #### can that cooler and valve
6.0_psd is offline
post #7 of 17 (permalink) Old 03-29-2014, 05:48 AM
"Slap hands slap hands"
FlossyB's Avatar
Re: EGR nightmare
delete that thing will fix all your problems did for me and I haven't had a issue with emissions at all which we have where I live.
JB
FlossyB is offline
post #8 of 17 (permalink) Old 03-29-2014, 01:39 PM
Jackleg Mechanic
mastrkee's Avatar
Re: EGR nightmare
Maybe the little scoop in the up pipe is burned off or for some other reason it's just not pushing enough flow through to satisfy the system. Time to pull the intake and cooler off for a visual inspection. Or delete.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #9 of 17 (permalink) Old 03-29-2014, 02:54 PM
'05 Excursion
Term3's Avatar
EGR nightmare
Check your wiring harness for chaffing. I thing is grounding out somewhere.
Sent from AutoGuide.com App
Term3 is offline
post #10 of 17 (permalink) Old 03-29-2014, 10:19 PM Thread Starter
Garage
Re: EGR nightmare
And we have a winner, Going back to square one the back FICM connector fell apart in my hand. I thought about just changing the connector, but as I was disassembling the connector it crumbled. At that point I chose to change the harness.
Bulletproof also advised to go back to the stock air cleaner. I was researching that and found that a stock 6.0L have issues with intake system. I have not driven it enough to say with absolute certainty that it is fixed, but the idle is much quieter then before.
