can it be anything besides head gasket?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-28-2014, 06:21 AM Thread Starter
I bought an 05 with ARP studs in it. My coolant cap has steam coming out from around it. No oil in coolant no coolant in oil. Egr delete done. Can it be anything besides my gaskets???
skeetreecetw is offline
post #2 of 5 (permalink) Old 03-28-2014, 06:26 AM
kellyrulzz's Avatar
Re: can it be anything besides head gasket??
Dumb question but, are you sure the cap is good and holding 16 lbs pressure?
2005 F-350 XLT SRW 4X4
EGR Delete
Banks Monster CAT Back
SCT SF3
Stock Headbolts
Looney by Eric from Quick Tricks Auto!
Street King by Drew.
kellyrulzz is offline
post #3 of 5 (permalink) Old 03-28-2014, 06:28 AM Thread Starter
No I did replace it with an o relies cap. But I really dont think it ever sealed many the threads on the tank were cross threaded from the old cap?
post #4 of 5 (permalink) Old 03-28-2014, 06:35 AM
kellyrulzz's Avatar
Maybe get a new degas bottle or a used one from a wrecking yard, they gotta hold the 16 lbs or it will cause overheating issues because coolant boils easier at lower pressures.
EGR Delete
SCT SF3
Stock Headbolts
post #5 of 5 (permalink) Old 03-28-2014, 07:02 AM
2002 7.3L
Ryanisme23's Avatar
The reason for the 16 lbs of pressure required for the cap to seal is to create a lower boiling point temperature due to pressure. If its cross threaded, either get the new cap to seat properly on the degas bottle or get a new one like Kelly has just stated. You may want to keep an eye on your temperature gauge and make sure its not bouncing around which will probably mean issues with your thermostat. keep us posted dude!
02 7.3L LARIAT
K&N COLD AIR INTAKE
4" EXHAUST WITH 5" CROME TIP
EDGE PROGRAMMER
4" LIFT WITH 35" NITTO TG's
OPEN COUNTRY BULL BAR
6" KC LIGHTS BAR MOUNTED
Ryanisme23 is offline
