electrical not wanting to stay running - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-28-2014, 03:57 AM Thread Starter
2007 f250 stock. 2 months ago came out gym dead, had alternator checked said was good and the batteries were shot got 2 new ones. wife driving and lights started flickering and she pulled over and it died. was jumped and it ran for half mile then died, gave fuse code for trailer connect. I had it towed home replaced fuse got it started then died. this is my first diesel and I am lost. had 2 heads put on 6 months ago and a sensor. I need information cause I hate paying for others to do things that I can do. I am mechanically incline with gas. if I could get like a check list type thing would be great.
dyllan1 is offline
post #2 of 8 (permalink) Old 03-28-2014, 04:48 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: electrical not wanting to stay running
How long after the new batteries before it happened again?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 8 (permalink) Old 03-28-2014, 07:18 AM
2002 7.3L
Ryanisme23's Avatar
Possible alternator issues present themselves the fastest when you are running with your headlights on. The batteries have one main purpose and that is to start the truck. after startup, the alternator charges the batteries to maintain voltage between 12volts-15volts.
02 7.3L LARIAT
K&N COLD AIR INTAKE
4" EXHAUST WITH 5" CROME TIP
EDGE PROGRAMMER
4" LIFT WITH 35" NITTO TG's
OPEN COUNTRY BULL BAR
6" KC LIGHTS BAR MOUNTED
Ryanisme23 is offline
post #4 of 8 (permalink) Old 03-28-2014, 10:01 AM
"Slap hands slap hands"
FlossyB's Avatar
sounds like alternator to me.
JB
FlossyB is offline
post #5 of 8 (permalink) Old 03-28-2014, 03:04 PM Thread Starter
It was within 2 weeks from getting the 2 new batteries. I am going to check the alternator this weekend and change batteries around.
dyllan1 is offline
post #6 of 8 (permalink) Old 03-28-2014, 04:13 PM
Big dumb redneck
6speedSD's Avatar
Garage
Yep, get the alternator checked again by somewhere different than last time. These days there is a growing number of "new" parts being bad right out of the box. Just because it's a new part doesn't mean you can rule it out.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #7 of 8 (permalink) Old 03-30-2014, 06:46 PM Thread Starter
it was the alternator I got a better higher amp one I took it to two places to make sure it was not working since it just checked out ok not to long ago and thank you all for you time and input,
dyllan1 is offline
post #8 of 8 (permalink) Old 03-30-2014, 07:16 PM
Big dumb redneck
6speedSD's Avatar
Garage
Good deal. Glad you figured it out.
Might want to check your FICM voltages now just to be on the safe side since you were running with a weak charging system.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
