perturbing fuel guage issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-26-2014, 12:57 AM Thread Starter
Olblue0460's Avatar
Took my truck to shop to check why fuel gauge wasn't working properly, had it completely gone through and he said it came down to the sending unit is bad. So ordered a new one and was easily pulled old one out and dropped new one in without touching or modding anything on it, was exact same unit, well now the needle doesn't even move, it barely jumps a hair, but doesn't go up to show I have any fuel at all, did my best to try to follow wires but once they go into another plug I lose them and haven't the faintest what wire it is tiat goes to the dash, with that said, was wondering if by chance one thing that might help my gauge work right now is to do the blue spring upgrade to put the fuel pressure back up where it needs to be because mine is running only 50 psi at idle. Any feedback would be awesome, thanks for yalls time.
Olblue0460 is offline
post #2 of 5 (permalink) Old 03-27-2014, 01:46 AM Thread Starter
Olblue0460's Avatar
Re: perturbing fuel guage issues
no one ???
post #3 of 5 (permalink) Old 03-27-2014, 01:59 AM
Big dumb redneck
6speedSD's Avatar
Garage
Blue spring raises your fuel pressure....has nothing to do with your fuel gauge. Sounds to me like something isn't hooked up right or connected well with the new sending unit. Or you have a short in the wiring somewhere.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #4 of 5 (permalink) Old 03-27-2014, 11:02 PM
$HUNGRY6.0
Can you use a test light to trace the wires? Put power to one wire at a time and check sequentially
2006 F350 cclb 6spd, studded, mbrp 5" TB, Full Force 225cc injectors, S467.7, custom pedistal & up pipes w/ext waste gate, egr delete, sinister coolant filter,new oem oil cooler, custom IC pipes, Thumper II HPOP, RCD reg return, SCT custom tunes, southbend clutch single disk, custom fab 4.5" lift, 315/70r18 toyo mt
Esp0660 is offline
post #5 of 5 (permalink) Old 04-24-2014, 04:26 AM Thread Starter
Olblue0460's Avatar
Been a bit since been online, thx for the feedback, I will go thru and check all the wiring and see what I can come up with.
