PCM ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-26-2014, 01:09 AM Thread Starter
PCM ?
How specific are PCM's my mechanic is saying mine is the root of a recent no start situation on my 2004 with a February production date. He was able to find a PCM out of an 05 reprogram it and get it running but no gauges on the dash would work so he found one for a 2003 reprogrammed it and now its back to no start. So I guess my question is ho specific are the PCM's and is he just not trying to find the right one.
ofdscooby is offline
post #2 of 12 (permalink) Old 03-26-2014, 02:36 AM
Re: PCM ?
05+ will not work for 2004
(6.0L, diesel), engine control, low emissions, AT, ID 3C3A-BFE thru BFM
(6.0L, diesel), engine control, low emissions, AT, ID 3U7A-CVA, FUA & FUC
(6.0L, diesel), engine control, low emissions, AT, ID 4C3A-ARF & ARG
(6.0L, diesel), engine control, low emissions, AT, ID 4C3A-AUF & AUG
(6.0L, diesel), engine control, low emissions, AT, ID 4C3A-AYF & AYG
(6.0L, diesel), engine control, low emissions, MT, ID 3C3A-BJE thru BJM
(6.0L, diesel), engine control, low emissions, MT, ID 3U7A-CSA
(6.0L, diesel), engine control, low emissions, MT, ID 3U7A-FRA thru FRD
(6.0L, diesel), engine control, standard emissions (Fed), AT, Harley-Davidson, ID 4C3A-AXF & AXG
(6.0L, diesel), engine control, standard emissions (Fed), AT, exc. Harley-Davidson; ID 3C3A-BDD thru BDM
(6.0L, diesel), engine control, standard emissions (Fed), AT, exc. Harley-Davidson; ID 3U7A-CUA
(6.0L, diesel), engine control, standard emissions (Fed), AT, exc. Harley-Davidson; ID 3U7A-FTA thru FTE
(6.0L, diesel), engine control, standard emissions (Fed), AT, exc. Harley-Davidson; ID 4C3A-ATF & ATG
(6.0L, diesel), engine control, standard emissions (Fed), AT, exc. Harley-Davidson; ID 4C3A-ATH
(6.0L, diesel), engine control, standard emissions (Fed), AT, exc. Harley-Davidson; ID 4U7A-EGA, EGB, EGD & EGG
(6.0L, diesel), engine control, standard emissions (Fed), MT, ID 3C3A-BHD thru BHM
(6.0L, diesel), engine control, standard emissions (Fed), MT, ID 3U7A-CRA
(6.0L, diesel), engine control, standard emissions (Fed), MT, ID 3U7A-FPA thru FPD
(6.0L, diesel), engine control, standard emissions (Fed), MT, ID 4C3A-APF & APG
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #3 of 12 (permalink) Old 03-26-2014, 02:39 AM
Re: PCM ?
Pcm vary very rarely go bad
wise guy is offline
post #4 of 12 (permalink) Old 03-26-2014, 02:51 AM
'05 Excursion
Term3's Avatar
PCM ?
Yes, I've never seen one fail either. You sure he didn't mean the FICM?
Sent from AutoGuide.com App
Term3 is offline
post #5 of 12 (permalink) Old 03-26-2014, 03:20 AM
Re: PCM ?
I have seen 2 TOTAL one no communication other had no rpm cranking good signal back probed with lab scope nothing on scan tool.
He said PCM
wise guy is offline
post #6 of 12 (permalink) Old 03-26-2014, 04:41 AM
SledDogg's Avatar
Re: PCM ?
Side note..... what is different in the Harley Davidson pcm(ecm) vs. Non H.D.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #7 of 12 (permalink) Old 03-26-2014, 05:00 AM
Re: PCM ?
instrument cluster
I'm not 100% but I believe the o4 Harley configured more like 05my
wise guy is offline
post #8 of 12 (permalink) Old 03-26-2014, 05:05 AM Thread Starter
Re: PCM ?
Drove it on a Saturday and wouldn't start Sunday morning had it towed in and my guy has just been stumped he said he pulled about 20 codes off it 3/4 of them disappeared when he tried to use a PCM off a 2005 the FICM is only about 2 months old and was a half shell swap from FICMUSA.com I've done about half a days research trying to find PCM's and it seems they are very specific and found a ton on eBay but just wanted to ask.
post #9 of 12 (permalink) Old 03-26-2014, 05:52 AM
dsberman94's Avatar
Re: PCM ?
If you partially drained the batteries cranking it trying to start it that can throw codes from having low power.
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #10 of 12 (permalink) Old 03-26-2014, 05:54 AM
Re: PCM ?
ask what codes "dtc's " are
wise guy is offline
