Transmission Knowledge - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-24-2014, 11:12 PM Thread Starter
I have a 2003 F250 6.0l and the trans temp gauge started doing the jumping between cold and hot and then occasionally working fine thing. Obviously, there is a problem with the sensor. I did notice during this time that the trans would shift hard when not reading right. I ordered a new sensor and am waiting on it to come in the mail. Today the trans seemed to shift slowly at times, fast and hard at times and once did not want to shift in OD then started to shutter a bit. Any knowledge would be much appreciated!
I should mention that I had the Turbo replaced a couple weeks ago and the shop flashed over/removed my custom tunes. I tried today, after talking to Eric from Innovative, to put one of the tunes back on. this is when I realized that they had removed my old tunes the wrong way and now I have to send my tuner in to get it unlocked. Could this be a possible source of my issues?
2003 F250 King Ranch 6.0L. MBRP SS exhaust, Cat Delete, SCT Tuner with Innovative Tunes, Sinister Coolant Filter, 4" lift, 35's.
PatJ is offline
post #2 of 12 (permalink) Old 03-24-2014, 11:16 PM
Administrator
Zmann's Avatar
Re: Transmission Knowledge
why the hell did the shop flash your PCM/ECM ? I would ask them and maybe let them know they cost u 150 bucks plus shipping then make a label for your OBD stating no re flash
I think the issues are your sender like you mentioned and the shifting is to
not to mention the system is in adaptive relearn from the flash
but these are guesses on my part Mark K may chime in with the undisputable facts
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 12 (permalink) Old 03-25-2014, 12:23 AM Thread Starter
Man, I hope that's all it is..... I don't need another costly repair so soon!
PatJ is offline
post #4 of 12 (permalink) Old 03-25-2014, 01:04 AM
Replace the internal harness as well as tft sensor both have been updated. sensor issues are common and the wire harness likes to chafe and short on valve body. Both will cause temp gauge to spike
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #5 of 12 (permalink) Old 03-25-2014, 09:55 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The transmission is always in adaptive learn. It learns continuously over the life of the truck. It never stops adapting.
Fix the temp sender issue then see if the trans is working right.
Mark
Mark Kovalsky is offline
post #6 of 12 (permalink) Old 03-25-2014, 07:36 PM Thread Starter
Thanks for the help! I'll be changing the sender and hopefully the harness this weekend and will monitor it after that.
PatJ is offline
post #7 of 12 (permalink) Old 03-26-2014, 01:29 AM
Administrator
Zmann's Avatar
so whats the term u would use when the PCM is cleared
and the transmision is shifting funny until u either do the below or drive it long enough to start shifting normal ? relearn period ?? IDK
5r110 Shift Relearning Strategy TorqShift Harsh/Slipping Engagements, Upshifts, and/or Downshifts: If these symptoms are experienced after the batteries have been disconnected, then it is due to the transmission adaptive strategy being cleared from the computer. This may occur when the vehicle is delivered new from the factory as well. 1. Warm the engine and transmission to operating temperature with all accessories off. 2. Idle engine for one minute with engine warm and all accessories off. 3. Idle engine for one minute with A/C on. Then: 1. While driving, perform three series of upshifts at light, medium and heavy throttle. 2. While stopped, perform three sets of gear engagements (N-R, N-D, D-R, R-D) with the brake pedal firmly depressed and waiting three seconds between each engagement. Perform these steps once in normal mode and once in tow/haul.
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 12 (permalink) Old 03-26-2014, 09:26 AM
I'd call that a faster way to get the learned tables filled in.
Mark
post #9 of 12 (permalink) Old 03-26-2014, 07:55 PM
Administrator
Zmann's Avatar
well coin an term for it
when the tables are empty we can't say it's in adaptive relearn because you schooled us better and we know it's always learning but when the KAM is wiped has no adaptive "table" it is using programmed defaults ?? seems like they would have been smoother rather than
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 12 (permalink) Old 03-27-2014, 03:25 AM
Yes, it uses programmed defaults.
Mark
