need oil cooler bypass valve - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-23-2014, 08:45 PM Thread Starter
sixohyeshrlydav's Avatar
Little history first, had coolant flush done, filter installed and elc coolant done over a year ago. Just got head gaskets done and changed oil cooler while in there because i had a 19 degree delta. Got truck all together but the delta is still 19 degrees. Only thing i can think is that the oil cooler bypass valve is opening. Ive looked for hours but can find the part and how to replace it. I think its just pulling oil filter then removing two torx holding the valve and spring in place but just wanted to be sure. BUT I still cant find the part. Anyone have any ideas? I would even like to get a used one as long as its not beat up.
2005 F250 6.0 Harley Davidson
Edge Insight w/ EGT sensor and Fuel Pres sensor, SCT w/ Gearhead Tunes, Warren 155/stock injectors, Headstuds, EGR Delete, engine updates, Metal Hotside CAC w/ Riff Raff boots, Sinister Coolant Filter with ELC coolant, 4" TB MBRP Exhaust with 6" SS tip, 17" MKW wheels with 35" Cooper Discover STT, Pioneer Headunit
sixohyeshrlydav is offline
post #2 of 9 (permalink) Old 03-24-2014, 12:43 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: need oil cooler bypass valve
What are your actual temps?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 9 (permalink) Old 03-24-2014, 12:55 AM
PursuitInterceptor
HeavyAssault's Avatar
It's the whole upper housing/ cover to the oil cooler. I don't think they sell just that small part.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #4 of 9 (permalink) Old 03-24-2014, 01:16 AM Thread Starter
Ect 174 eot 193 are my temps. One thing i did notice was i could get eot up to 207 then within a few minutes it would come down to 193.
I was afraid that it wasnt sold seperate. 180$ part to rob a 5$ part off it.
post #5 of 9 (permalink) Old 03-24-2014, 01:41 AM
diesel fiend
florida 6.0's Avatar
Your engine oil temp sounds fine , your coolant temp though is a lot lower than normal . Mine both always run in the 190's when its warm outside .
05 F350 9" 4 link , 37's , 4.56 's php and gearhead tuned
florida 6.0 is offline
post #6 of 9 (permalink) Old 03-24-2014, 01:56 AM
Big dumb redneck
6speedSD's Avatar
Garage
Sounds like your t-stat is sticking. Only time I've personally seen ECT temps that low is when that happens.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #7 of 9 (permalink) Old 03-24-2014, 12:04 PM
PursuitInterceptor
I'd swap out the Tstat first....easy and cheap.
You dig.
post #8 of 9 (permalink) Old 03-26-2014, 01:09 PM
I just did this yesterday. I was only seeing 160 ect and 195 eot. Swapped out the tstat now im seeing 185 190 ect and 220 225 eot. Im in need of a new oil cooler
Murdered6.0 is offline
post #9 of 9 (permalink) Old 03-26-2014, 08:43 PM
Big dumb redneck
6speedSD's Avatar
Garage
EOT shouldn't go up with a working t-stat, correct?? Or am I thinking about this wrong?
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
