Egr dilemma - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 03-22-2014, 09:26 PM Thread Starter
Nolo91's Avatar
Egr dilemma
Ok so I did my egr delete about 8 or 9 months back because my coolant was disappearing with no drip spots on the ground or anything I took the stock egr and sauntered up the sides well I'm having the same issue again what could this be I used half a gallon of coolant drivin from Mississippi to Texas
all or nothing
Nolo91 is offline
post #2 of 14 (permalink) Old 03-23-2014, 01:36 AM
2Dstorm's Avatar
Re: Egr dilemma
It's probably leaking out of your degas bottle onto the exhaust manifold and evaporating
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #3 of 14 (permalink) Old 03-23-2014, 01:44 AM Thread Starter
Nolo91's Avatar
Re: Egr dilemma
But the coolant looks like it boiling
all or nothing
Nolo91 is offline
post #4 of 14 (permalink) Old 03-24-2014, 01:26 AM Thread Starter
Nolo91's Avatar
Re: Egr dilemma
Anyone?
all or nothing
Nolo91 is offline
post #5 of 14 (permalink) Old 03-24-2014, 02:38 AM
JohnKBrown's Avatar
Re: Egr dilemma
Check the Hose under the degas bottle for wear/cracks. They get brittle over time and could, like said above, be dripping onto the manifold and evaporating.
2006 F250 6.0L Powerstroke (Sold)
1999 F350 7.3L XLT Bone Stock
112,000 Miles
JohnKBrown is offline
post #6 of 14 (permalink) Old 03-24-2014, 11:49 AM Thread Starter
Nolo91's Avatar
Re: Egr dilemma
Ok but what about the coolant looks like it's boiling in the degas bottle
all or nothing
Nolo91 is offline
post #7 of 14 (permalink) Old 03-24-2014, 08:05 PM
JohnKBrown's Avatar
Re: Egr dilemma
If its boiling in the degas bottle, more likely then not, have a leak somewhere. What are your coolant temps? Do you have the upgraded Degas Cap? The older version had issues with malfunctions, from what I read users would over tighten them instead of the stopping at the single click. I think they are supposed to pop at 16psi.
6.0L POWERSTROKE - HEAD GASKET TEST - YouTube
112,000 Miles
post #8 of 14 (permalink) Old 03-24-2014, 08:07 PM
JohnKBrown's Avatar
Re: Egr dilemma
Should be able to run a pressure gauge. Just monitor pressure at idle and then give it a good run. Try to find small grades or give her a little bit on a straight away. Good Luck.
112,000 Miles
post #9 of 14 (permalink) Old 03-24-2014, 08:15 PM
JohnKBrown's Avatar
Re: Egr dilemma
Did you freeze plug the stock egr? No offense to you buts its common to have them fail when not done properly, your better off just getting a Bulletproof Diesel EGR Cooler. Limited Lifetime Warranty and a great track record, good replacement if your state looks for it during emissions.
112,000 Miles
post #10 of 14 (permalink) Old 03-24-2014, 10:53 PM Thread Starter
Nolo91's Avatar
Re: Egr dilemma
Yea freeze plugged the egr did it that way just till I got the money to do studs and all
all or nothing
Nolo91 is offline
