Injector vs ficm or both - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-22-2014, 05:00 PM Thread Starter
tmorse686's Avatar
It got really cold here and ever since then my truck has been throwing a cylinder 5 contribution code and starting super rough when started it also throws a ficm code. If I erase the codes while running just a contribution code stays is if my ficm injector or both?
tmorse686 is offline
post #2 of 3 (permalink) Old 03-22-2014, 06:18 PM
Outlaw wrench
towin stroker's Avatar
Re: Injector vs ficm or both
test your ficm. easy to do. that way you will know where your problem is.
My exhaust makes more horsepower than your import!
03 ccsb fx4 5r110 trans
bulletproof 58v ficm
egr deleted
MBRP 4" straight pipe
zoodad mod
blue fuel spring
edge insight cts monitor only
leveled with 2" add a leaf
bilstien 5100 shocks
new oil cooler/radiator/t stat
EDP direct solenoid
sct with IDP tunes
towin stroker is offline
post #3 of 3 (permalink) Old 03-22-2014, 09:50 PM
Fixing Broken Stuff
toolmangary's Avatar
What was your FICM code? P0611? if so you probably need a FICM, then after that see if you still have the injector code, if so then most likely you need a injector.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
