is it absolutely necessary to remove passenger side block plug when flushing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-21-2014, 06:38 PM Thread Starter
I have green coolant and switching to elc. Do I really need to take the passengers side block out to drain....its a pain in the butt
125py is offline
post #2 of 10 (permalink) Old 03-21-2014, 06:56 PM
Re: is it absolutely necessary to remove passenger side block plug when flushing
Nope. You can do it without taking out that plug.
blackpowderscout is offline
post #3 of 10 (permalink) Old 03-21-2014, 07:10 PM Thread Starter
Do you think I will be able to get all the green coolant out if I dont?
125py is offline
post #4 of 10 (permalink) Old 03-21-2014, 07:37 PM
Based on my limited experience (1 flush on a 6.4) combined with what I read while researching how to do it, YES. You can get it all out but you won't get all the water you use to flush it with out. So remember that when you are filling it up with new coolant.
Use a concentrate plus distilled water as needed, not a 50/50 pre mix. I ended up putting around 4 1/2 gallons of coolant in and it topped off, if I remember correctly. So it does hold a significant amount of water.
The key is to keep flushing until you are getting good clean fluid back out. Then you know all the old stuff is out. Some of the ELC's allow for a "contamination" with old coolant up to certain percentage anyhow.
Hope this helps.
post #5 of 10 (permalink) Old 03-21-2014, 07:42 PM
Administrator
Zmann's Avatar
it's not a huge pain to drop the starter
and if u don't install the Fumoto valves but want to access the plug a few times doing a flush you leave the one starter bolt out until your done
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 10 (permalink) Old 03-21-2014, 07:52 PM Thread Starter
Im using 100% distilled water and no chemicals for the entire flushes if that matters
125py is offline
post #7 of 10 (permalink) Old 03-21-2014, 08:21 PM
Won't mater. You'll still have water left over in there.
post #8 of 10 (permalink) Old 03-21-2014, 09:24 PM
Administrator
Zmann's Avatar
you will be fine without the one plug removed
if i were trying to get sediment out I would say it's a must but your just coolant swapping
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 10 (permalink) Old 03-21-2014, 09:27 PM
Administrator
Zmann's Avatar
not sure I wouldn't go hose water multiple times to get the coolant out then go distilled
2 times to get the minerals out compressed air can force more out of the open block plug if you put it to the dagas bottle carefully
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 10 (permalink) Old 03-21-2014, 09:44 PM
Most definitely!!!!! on the hose water. Flush with the cheap stuff then a few rinses with distilled and add coolant. Don't waste $$$.
