new member in need of help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-21-2014, 01:14 AM Thread Starter
Hello to all first of all! I'm having some issues with the fuel pressure on my truck and was hoping for some help! I have an 06 king ranch that has an Airdog 150 on it. I had gelled it up not real long ago. Before I gelled up it would sit at 60 psi for pressure at idle. After I got it home and warmed up I got it running and noticed it didn't have the power that I had prior to geling. I checked the fuel pressure again and the needle is a blur, bouncing between about 20 and 35. I can't figure it out at all. The Airdog is only a few months old. Could it be the fuel pressure regulator? Any info is appreciated!
Fordaddict is offline
post #2 of 6 (permalink) Old 03-21-2014, 02:11 AM
superbad's Avatar
Re: new member in need of help!
Airdogs aren't known for their reliability with the 6.0's.
Do a search for a 6.4 fuel pump. I hear it's much better and will help the stock 6.0 fuel pump keep up pressure.
2008 F250 KR CCSB AT MINIMAXX AFe PG7 5" straightpipe. SOLD!
2007 F250 KR 4x4 CCSB Scan Gauge II, SCT SF3, Gearhead's SRLXX, ARP's, PMM's EGR delete, PMM's coolant filter, Rancho 7000's, IDP FICM tuning, blue spring, Wicked Wheel, No Limit Fab CAI.
2006 GMC Savanna 3500 6.6 LBZ Duramax work van
superbad is offline
post #3 of 6 (permalink) Old 03-21-2014, 03:46 AM
Banned
Double check your regulator housing on the secondary fuel bowl. Make sure the spring there is not stuck.
miller45103 is offline
post #4 of 6 (permalink) Old 03-21-2014, 04:40 AM Thread Starter
I pinched off the return line then the gauge really went nuts! Makes me lean toward the regulator a little more. I will check it out tomorrow. Thanks for the info.
post #5 of 6 (permalink) Old 03-21-2014, 04:45 AM
Wyo
scouts out...
Wyo's Avatar
Did you change the filters after it gelled? That's pretty much common practice because the gel can damage the filters and cause blockage, let alone an opening for particles to get passed and not be filtered.
2007 CC, Lariat, 6.0L, TreadWright guard dogs, straight piped out the back, egr delete, blue spring, 6.4 banjo bolts, high idle mod(bcp), bulletproofed, SCT Livewire TS with Drews street runner(under development for high elevation), Innovative, and Vivian's tunes, ww2.
Wyo is offline
post #6 of 6 (permalink) Old 03-21-2014, 06:37 AM Thread Starter
Yes I did change them. Sorry I left that out.
