p0267/p0269 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-20-2014, 09:16 PM Thread Starter
oilfield trucker
zpilgeram's Avatar
p0267/p0269
For those of you who have been following along, I got the truck back up and running. Head studs and gaskets really weren't that bad! Now that I got the truck running tho, I'm getting two codes for cylinder #3, injector circuit low and contribution/balance. I'm assuming that's a pretty good indication of a bad injector? What's everyone's thoughts on this? Thanks!
96cc,lb,4x4,zf5. DIY dual filter intake, intercooled,gauges,4''down pipe, DIY front bumper/grill guard,fuel tank mod, 238cc Rosewood Diesel hybrids,6pos chip from TDP,
stealth SRP1 HPOP,Garrett GT4294 with DIY mounting kit,valair 500hp kevlar/ceramic clutch,Dual SD pumps electric fuel system with regulated return,5'' DIY Straight pipe.
zpilgeram is offline
post #2 of 4 (permalink) Old 03-21-2014, 12:05 AM
Six Point Slow
justinstorm77's Avatar
Re: p0267/p0269
got a dead hole there, either injector or compression issue. is it missing?
justinstorm77 is offline
post #3 of 4 (permalink) Old 03-21-2014, 02:13 AM Thread Starter
oilfield trucker
zpilgeram's Avatar
Re: p0267/p0269
It's missing some what I'd say, although you can't really hear it, you can feel it. It shudders pretty good in overdrive when you lightly accelerate and when it's cold you can feel it loping and surging, also, when it's idling it feels a little rough and almost sounds like it's chugging a little. It doesn't have that nice crisp 6.0 idle. I was reading up on stiction earlier. What's the possibility of that being my problem?
post #4 of 4 (permalink) Old 03-21-2014, 04:04 PM
matthewd11's Avatar
Re: p0267/p0269
make sure the injector and ficm are plugged in all the way.
matthewd11 is offline
