stick with T6 or go to dino oil for summer towing? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-19-2014, 06:56 PM Thread Starter
Napadan's Avatar
So I am currently running T6 and was wondering if I should switch to a non-synthetic for warmer weather and towing season? Used to have to do this with my 5.4 half ton or it would use a quart before each oil change. Thoughts?
05 F250 SCLB. 75k Water filter, blue spring upgrade,Magnaflow 4" turbo back system w/muffler and SCT tuner with custom tunes by Drew.
Napadan is offline
post #2 of 8 (permalink) Old 03-19-2014, 09:38 PM
Bobs 7.3
Bobs 7.3's Avatar
Re: stick with T6 or go to dino oil for summer towing?
I run t-6 all year but I also have a 7.3. I never use oil between my 7000 mile oil change mark. The t6 still has the 40w protection for the heat as the dino oil only better protection being syn and faster flow when cold as its 5w compared to 15w.
Bobs 7.3 is offline
post #3 of 8 (permalink) Old 03-19-2014, 11:43 PM
Banned
If you have used (worn) injectors, run 5-40. If you have new injectors (modified solenoids) run 15-40
miller45103 is offline
post #4 of 8 (permalink) Old 03-20-2014, 03:40 PM Thread Starter
Napadan's Avatar
The dealership put 8 "new" reman in about a month ago but they are stock solenoids. So I should be ok with the T6 on those?
Napadan is offline
post #5 of 8 (permalink) Old 03-20-2014, 03:42 PM
Banned
Yes. All injectors you get from the dealership are remand
sent from my smart car
post #6 of 8 (permalink) Old 03-20-2014, 09:10 PM Thread Starter
Napadan's Avatar
Thx Miller will just keep running my T6 then
Napadan is offline
post #7 of 8 (permalink) Old 03-20-2014, 09:18 PM
Administrator
Zmann's Avatar
t6 5-40 24/7/365
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 8 (permalink) Old 03-22-2014, 06:36 PM
Outlaw wrench
towin stroker's Avatar
Talking Re: stick with T6 or go to dino oil for summer towing?
T6 all year long in Arizona! No issues
My exhaust makes more horsepower than your import!
03 ccsb fx4 5r110 trans
bulletproof 58v ficm
egr deleted
MBRP 4" straight pipe
zoodad mod
blue fuel spring
edge insight cts monitor only
leveled with 2" add a leaf
bilstien 5100 shocks
new oil cooler/radiator/t stat
EDP direct solenoid
sct with IDP tunes
towin stroker is offline
