ipr and icp on scangauge - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 03-19-2014, 01:51 PM Thread Starter
Alright so here we go ive been searching the internet for days to figure this out. I got my scan gauge hooked up reading ect, eot, ipr duty cycle, and icp pressure. At idle fully warmed up im seeing 28% duty cycle and around 800 psi at idle. Cruising around 2000 im seeing 50% duty cycle and around 1700 psi. engine coolant temp is 160 and engine oil temp is 180 to 190. At full throttle I see 89.9% duty cycle and 930 psi icp pressure. I have new standpipes and dummy plugs new seals for the high pressure cups and injectors seals is where I am going to start. What do you guys think could be causing this issue.
Murdered6.0 is offline
post #2 of 16 (permalink) Old 03-19-2014, 03:46 PM
carolina7.3's Avatar
Re: ipr and icp on scangauge
Looks. Like the hpop is straining my 7.3 at wot 2800 psi at 48%
E99 F-250 Mfd Jan 98, 6637, 6fin billet comp wheel, from riffraff.com, stage I & II ebp delete, 86ed, ScanGauge II, TJM bull bar, bosch field burners, 4" downpipe 4" single stack, Hutch n Harpoon Mod, galaxy dx 44v, PHP Hyrda
E99, F350 CCLB, DRW, RR comp wheel, Superchip 1705, couple other mods
chris
carolina7.3 is offline
post #3 of 16 (permalink) Old 03-19-2014, 04:18 PM Thread Starter
im hoping I don't have to put a new hpop in the truck
post #4 of 16 (permalink) Old 03-19-2014, 09:05 PM
unplug icp is their oil in the plug? have you ever replaced the icp?
chris
post #5 of 16 (permalink) Old 03-19-2014, 09:07 PM
jfarmer86's Avatar
It is not your HPOP as stated above.... Is it falling on its face when your driving?
jfarmer86 is offline
post #6 of 16 (permalink) Old 03-19-2014, 11:51 PM
Banned
Get your engine coolant temp up to the proper range (180-195) before you do any diagnosing.
miller45103 is offline
post #7 of 16 (permalink) Old 03-20-2014, 11:41 AM Thread Starter
There's my first issue the hottest the truck gets is 160 degrees. I need to do a thermostat this weekend
post #8 of 16 (permalink) Old 03-20-2014, 11:41 AM Thread Starter
ICP sensor was replace 1.5 years ago by KEM Performance in Georgia. I have not unplugged the icp and taken it out to look at it
post #9 of 16 (permalink) Old 03-20-2014, 11:42 AM Thread Starter
Yes it falls on its face when I drive it..
post #10 of 16 (permalink) Old 03-20-2014, 12:07 PM
jfarmer86's Avatar
I would look into ICP first, if you voltage is low/jumping around. If not then try replacing your IPR
