Sterling 10.5 broke last weekend, what parts to use to fix - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 03-18-2014, 03:26 PM Thread Starter
300,000 and counting's Avatar
Hauling cows with the farm truck,2007 f350 4x4 SRW, this last weekend and going up a steep hill from a dead stop loaded the rear end went out. I haven't pulled it apart yet but it sounds like the ring and pinion doesn't have any teeth left, the drive shaft and input shaft into the axle spins but the truck doesn't move and the rear end goes clunk clunk clunk. So not 100% knowing what's wrong yet what would be the best parts to put back in and not break the bank or the rear end again. Any help would be great, links would be great the truck has a zf6 and 4:10's.
Also a Dana 80 wouldnt be out of the question from a 99-04 drw if there is an easy way to make the Dana 80 match sterling 10.50 in length so the tires are in the factory position.
2001 7.3 PSD, Swamps 200/30 injectors, 38r turbo, HPx, FRx, bellowed up-pipes, non-ebpv ped, Gearhead tuned TS 6 pos chip, AFE big boost intake, 4" downpipe; 5" exhaust, BTS valve body, 31 row tranny cooler, autometer gauges, 05-07 front end, centurion rear bumper, 327,000 miles FOR SALE
2009 6.4 PSD, 71mm LP, studded, delete, H$S Mini Max
300,000 and counting is offline
post #2 of 14 (permalink) Old 03-18-2014, 05:50 PM
2Dstorm's Avatar
Re: Sterling 10.5 broke last weekend, what parts to use to fix
You got 300k + outta the stock stuff I would go back the same.. It will be easier then trying to switch it all out. 300k is proven enough for me.
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #3 of 14 (permalink) Old 03-18-2014, 07:33 PM Thread Starter
No the farm truck has 102,000 miles on it the one with 320,000 is my personal truck; the farm truck basicly never leaves the trailer. We only had the farm truck for like 3 years 15,000 miles
post #4 of 14 (permalink) Old 03-18-2014, 07:43 PM
Administrator
Zmann's Avatar
i might get a low mile take out if you didn't have the 4:10's that will be harder to find
if it's just a pinion or something easy i agree the sterling is no slouch put it back together and go if it spit gears i worry about housing integrity
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 14 (permalink) Old 03-19-2014, 04:57 AM
Fixing Broken Stuff
toolmangary's Avatar
I'd pull the cover off and see whats broke first, you may just need some spiders.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #6 of 14 (permalink) Old 03-31-2014, 05:13 AM Thread Starter
Well figured that out, we're getting a new/used axle Monday for $700 with a 6 month warranty if we return it has 114,000 miles on it.
post #7 of 14 (permalink) Old 03-31-2014, 12:19 PM
Fixing Broken Stuff
Yeah, that made some noise.
2004 Jetta TDI
1956 F100
post #8 of 14 (permalink) Old 03-31-2014, 01:42 PM
Administrator
Zmann's Avatar
good call on ditching that one
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 14 (permalink) Old 03-31-2014, 07:35 PM
Professional American, guarding our constitution. Gone, but not forgotten.
Mr_Andy's Avatar
Never liked the Sterling rears, regardless of whether they were made under the Ford empire or the brief lifespan that Viseton experienced on their own. Seeing that pic helps me understand why Viseton went out of business.
Also, I guess from what you said you won't be going with the D80 idea you had, just keep in mind that's a 10 lug axle and you'd have to make accommodations accordingly...
Mr_Andy is offline
post #10 of 14 (permalink) Old 03-31-2014, 08:08 PM Thread Starter
10 lug??? what is 10 lug a the dana 80's that came in the 99-10 drw f350 where 8lug and the same bolt pattern as the sterling 10.5
