Coolant? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-17-2014, 05:22 PM Thread Starter
Nolo91's Avatar
Coolant?
So I filled up my coolant before I left to drive about 2 hours then once I got here I checked it and it was all gone so I opened the cap and let it release pressure and some came back in I have an egr delete( stock egr with freeze plugs) what could be causing this
all or nothing
Nolo91 is offline
post #2 of 7 (permalink) Old 03-17-2014, 05:37 PM
2Dstorm's Avatar
Re: Coolant?
You were probably low check the degas bottle for leaks usually on the bottom side where the hoses connect. Also check where you park for leaks these systems seen to be fine until they are left overnight. I had a water pump that was leaking overnight but not when running
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #3 of 7 (permalink) Old 03-17-2014, 05:46 PM Thread Starter
Nolo91's Avatar
Re: Coolant?
Well this is the 3rd time in the past few days putting some in it
all or nothing
Nolo91 is offline
post #4 of 7 (permalink) Old 03-17-2014, 06:04 PM
2Dstorm's Avatar
Re: Coolant?
Are you white smoking?
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #5 of 7 (permalink) Old 03-17-2014, 06:43 PM Thread Starter
Nolo91's Avatar
Re: Coolant?
Only on cold start when engine cranks then no smoke when driving or anything
all or nothing
Nolo91 is offline
post #6 of 7 (permalink) Old 03-17-2014, 06:52 PM
2Dstorm's Avatar
Re: Coolant?
Worse case, you got bad hg or head it's leaking into the cylinder over night smokes when you start it. Engine get hot it seals up while driving.... That being said we all think of the worse case when it comes to the 6.0,
Water in the oil?
Fuel in the water (your degas would be foamy)
Leaking hoses or degas bottle?
Leaking water pump?
Leaking heater core?
I would def. start with the small stuff
How long has it been since you did your egr/oil cooler
Have you been running your heater?
System could have just purged all the air out the heater core is the high point and can hold air for a while.
It could be all kinds of things I would start with checking visually for leaks in the morning after the truck has cooled down over night. A little white smoke may be just condensation from sitting over night.
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #7 of 7 (permalink) Old 03-17-2014, 06:56 PM Thread Starter
Nolo91's Avatar
Re: Coolant?
Ok I will check all those
all or nothing
Nolo91 is offline
