Power Problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-17-2014, 04:15 AM Thread Starter
05stroker
slow89's Avatar
Power Problems
hi I am new to the site but have been reading info from here for awhile. I have a problem I cant seem to figure out. First off my truck is a 2005 f250 Head studs,egr delete, 4inch turbo back with S&B intake. I have a sct tuner with innovative tunes on it. So I went to the track today and had it on extreme x tune. Had the truck in 4x4 launch was fine but truck feels like it falls down. Went 14.40 @ 92mph. Then I put in on the anarchy tune and it went 14.29 @93mph. On my way home I put in on the performance tune and it feels way faster than any of the higher tunes. Im thinking it has to be a fuel problem. Anyone els had this problem. Also the tires a 33inch tall.
slow89 is offline
post #2 of 11 (permalink) Old 03-17-2014, 02:29 PM
spence_08's Avatar
Re: Power Problems
Go get ur self a blue spring update. See if that helps
08 superduty 6.4 fx4 sct live wire 9625or edge evo monitor flow pro 5 inch downpipe back. Afe stage 2 cold air intake 35 inch mickys on 18 revolver rims. dpf delete ccv mod
01 TDI jetta . Strait piped runnin on B100 summertime and B50 in the winter.
DRIVE IT LIKE YOU STOLE IT !
spence_08 is offline
post #3 of 11 (permalink) Old 03-17-2014, 02:42 PM Thread Starter
05stroker
slow89's Avatar
Re: Power Problems
Yes that was what I was thinking I just ordered it from ford. I should have it tomorrow and will install.
05 F250 studs,egr delete with innovative tune
slow89 is offline
post #4 of 11 (permalink) Old 03-17-2014, 08:03 PM
JohnKBrown's Avatar
Re: Power Problems
Sounds like your injectors aren't able to keep up.
Do you still have a stock pump? Stock Injectors?
Might want to start there.
Stage 1 Injectors/Regulated Return/Upgraded pump sound like realistic upgrades if you plan on staying at the track.
Just my 2 Cents.
2006 F250 6.0L Powerstroke (Sold)
1999 F350 7.3L XLT Bone Stock
112,000 Miles
JohnKBrown is offline
post #5 of 11 (permalink) Old 03-17-2014, 09:39 PM Thread Starter
05stroker
slow89's Avatar
Re: Power Problems
I would like to do that but ive seen a lot of people with my set up with no peoblems. I was looking in doing the fuel system with 190cc and powermax
slow89 is offline
post #6 of 11 (permalink) Old 03-17-2014, 10:26 PM
SledDogg's Avatar
Re: Power Problems
Blue spring totally changed my stock 100k truck. Fuel mpg went up empty and towing. Great essential $74 mod. Install new cover....it is slightly different.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #7 of 11 (permalink) Old 03-18-2014, 03:22 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Power Problems
Get some way to monitor fuel pressure. See what it's doing when you hammer down on it.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #8 of 11 (permalink) Old 03-18-2014, 03:22 AM
JohnKBrown's Avatar
Re: Power Problems
I did it too but you can only expect to go so long with a street setup at the track. Good Luck to you. The blue spring upgrade will only take 30-45 mins with basic hand tools.
112,000 Miles
post #9 of 11 (permalink) Old 03-18-2014, 02:36 PM Thread Starter
05stroker
slow89's Avatar
Re: Power Problems
im going to do that today with my scanner.
slow89 is offline
post #10 of 11 (permalink) Old 03-18-2014, 05:56 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: Power Problems
You may want to use 6.4 banjo bolts, with the blue spring and 6.4 banjo bolts you should be good to 500 HP.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
