High pitch noise at idle - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-17-2014, 03:58 AM Thread Starter
I have a high pitch noise that is intermittent when idling. I cant tell if its a pulley or even the turbo. I am totally new to owning a diesel and I have an 05 F-250 6.0. Any advise would be greatly appreciated!
Jnjrup is offline
post #2 of 6 (permalink) Old 03-17-2014, 02:28 PM
spence_08's Avatar
Re: High pitch noise at idle
Take ur belt off and spin all your pullys. If thatss not it then pull ur intake boot off the turbo and check for play in the shaft could be bad bearings.
08 superduty 6.4 fx4 sct live wire 9625or edge evo monitor flow pro 5 inch downpipe back. Afe stage 2 cold air intake 35 inch mickys on 18 revolver rims. dpf delete ccv mod
01 TDI jetta . Strait piped runnin on B100 summertime and B50 in the winter.
DRIVE IT LIKE YOU STOLE IT !
spence_08 is offline
post #3 of 6 (permalink) Old 03-17-2014, 07:53 PM Thread Starter
Thank you!
Jnjrup is offline
post #4 of 6 (permalink) Old 03-17-2014, 07:55 PM
2Dstorm's Avatar
Loosen the cap on the degas bottle and see of it goes away
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #5 of 6 (permalink) Old 03-18-2014, 02:14 AM
Currey's Avatar
How many miles? I just had a similar noise (I likened mine to birds chirping or squealing). Took my serpentine belt off and, low and behold, it was the idler pulley bearing. To a of t. play in it. You can replace the bearing (p/n 203FF) or I just replaced the entire pulley and wheel. While you're at it, might as well replace the belt too. Good luck!
Currey is offline
post #6 of 6 (permalink) Old 03-18-2014, 02:48 AM
whistle tits
ghohouston's Avatar
O.p., you could also have a pre turbo exhaust leak, but definitely check everything else listed too
ghohouston is offline
