AIR DOG 2 Fuel pressure issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-16-2014, 04:39 PM Thread Starter
Regulator1988's Avatar
Angry AIR DOG 2 Fuel pressure issue
I have an air dog 165 and at idle it has 60 PSI but when I go WOT it drops to somewhere around 25 psi!!! I just put a new motor in it and a new fuel filter and no change. Voltage to the pump is fine.... Help?...
2003 F250 XLT 4 Door Long Bed
LT 265/75/16 Goodyear Silent Armor
Dura-Stroke Turbo Built by Adrian,Warren 175CC Injectors, AIR DOG 2, EDGE CTS Programmer, 4in Diamond Eye Straight Exhaust, S&B Intake, ARP Studs, New Oil Cooler 8/12, BPD EGR Delete, Blue Spring upgrade, SCT Custom Tuned, FICMrepair.com's Atlas 40 tune,
Regulator1988 is offline
post #2 of 6 (permalink) Old 03-16-2014, 05:29 PM
Good ol boy
04 f350's Avatar
Re: AIR DOG 2 Fuel pressure issue
You and everybody else that has an AD2 has had this issue before, I have one as well and have always had that same issue, mine doesn't drop quite as far as yours does but it does go to around 40-45ish, I personally think its just a crappy made fuel pump, I've replaced my motor 4 times and it still ends up the same. I have heard that blocking the return line is suppose to help so the regulators aren't fighting each other, you could try that and see what happens
Studded and Deleted
5 inch axle dump
Back Road Performance Tuned
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #3 of 6 (permalink) Old 03-16-2014, 06:45 PM
JGman141
Jgman141's Avatar
Blocking the the factory regulator will help alittle with stress on the pump. I had a ad2 with 205s and it would drop like a rock at WOT, only way to permanently fix the ad2 is to delete it.
Jgman141 is offline
post #4 of 6 (permalink) Old 03-16-2014, 09:13 PM Thread Starter
how do you block the factory regulator??
do you guys think i need to replace the water filter
post #5 of 6 (permalink) Old 03-16-2014, 09:37 PM
Good ol boy
04 f350's Avatar
You can cut a round piece from a soda can to block it, as for the water filter if I ain't mistaken those are rated for like 20k or so miles before it needs to be replaced
Studded and Deleted
5 inch axle dump
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #6 of 6 (permalink) Old 03-16-2014, 11:33 PM Thread Starter
ok I guess ill try to do both thanks man !
