Icp sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-16-2014, 03:48 AM Thread Starter
cope102's Avatar
Icp sensor
My truck been idling like it was missing scanned for codes. And had icp sensor code. I put new icp sensor in and truck won't start now.... so I put the old one back on and it fired right up... bad sensor?? What yall think?
2004 F350 DRW FX4 Banks Six Gun Tuner,Egr delete, Adrenaline pump, Banks air, 4 inch straight pipe exhaust
cope102 is offline
post #2 of 6 (permalink) Old 03-16-2014, 03:58 AM
carolina7.3's Avatar
Re: Icp sensor
Where you get sensor? is it ford part? I just put aftermarket one on mine it ran for 3 hrs then died. I put original 13yr old factory icp back in it fired right up. I only changed it bc it was leaking a lil.
E99 F-250 Mfd Jan 98, 6637, 6fin billet comp wheel, from riffraff.com, stage I & II ebp delete, 86ed, ScanGauge II, TJM bull bar, bosch field burners, 4" downpipe 4" single stack, Hutch n Harpoon Mod, galaxy dx 44v, PHP Hyrda
E99, F350 CCLB, DRW, RR comp wheel, Superchip 1705, couple other mods
chris
carolina7.3 is offline
post #3 of 6 (permalink) Old 03-16-2014, 05:28 AM
Re: Icp sensor
its a bad sensor, aftermarket ones are junk and ive gotten ones from international that were bad out of the box
polish pete is offline
post #4 of 6 (permalink) Old 03-16-2014, 02:18 PM
"resident smarty pants"
Re: Icp sensor
It certainly sounds like a bad sensor, but you need to also inspect the ICP connector and wiring closely. The early ICPs were bad about leaking oil that degraded the insulation and caused intermitant no-starts. Where is your ICP located?
Mark
bismic1 is offline
post #5 of 6 (permalink) Old 03-16-2014, 09:18 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Icp sensor
Where is your ICP? Passengers valve cover or under the turbo?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #6 of 6 (permalink) Old 03-16-2014, 10:51 PM Thread Starter
cope102's Avatar
Re: Icp sensor
mine is on the valve cover..
cope102 is offline
