Looking for options - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-15-2014, 04:30 PM Thread Starter
Outlaw wrench
towin stroker's Avatar
Looking for options
So I installed an edge insight monitor on my 03 6.0(210k,all stock, straight pipe, egr valve disconnected) and so far I love the monitor. My issue is my ect and eot deltas seem to be about 20 degrees apart(ecgt 188-192 eot 210-220). I havent gone on a long drive yet( flat road, constant speed,ect.) so Im starting to thing its time for an oil cooler. I have searched the web and found a really inexpensive doorman replacement cooler($190). Anybody try one of these doorman coolers?
I have also found some of the ford coolers for $330 and up. when I replace the cooler I will do a flush before replacing the cooler and also plan on doing an egr delete (one less thing to worry about).
Any suggestions will be greatly appreciated. Thank you in advance.
My exhaust makes more horsepower than your import!
03 ccsb fx4 5r110 trans
bulletproof 58v ficm
egr deleted
MBRP 4" straight pipe
zoodad mod
blue fuel spring
edge insight cts monitor only
leveled with 2" add a leaf
bilstien 5100 shocks
new oil cooler/radiator/t stat
EDP direct solenoid
sct with IDP tunes
towin stroker is offline
post #2 of 3 (permalink) Old 03-16-2014, 12:30 AM
Powerstroke214's Avatar
Re: Looking for options
I'd go OEM only, not worth it to cheap out IMO. Do the flush in advance, so you don't knock any sediments loose, after you put in the new oil cooler. Do the delete at the same time too.
Sent from AutoGuide.com App
06 CCSB
leveled, 4" block, 5" exh, gearhead tunes
Studs n more on the way
Powerstroke214 is offline
post #3 of 3 (permalink) Old 03-16-2014, 04:43 PM Thread Starter
Outlaw wrench
I was hoping that someone has used the doorman. Ford part is sssoooo expensive!
I installed a doorman replacement degas bottle last year on a camping trip. The original developed a split and was spraying coolant all over. So far the doorman part has held up.
egr deleted
zoodad mod
blue fuel spring
EDP direct solenoid
sct with IDP tunes
