Need help with the Diagnosys! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 35 (permalink) Old 03-15-2014, 04:25 PM Thread Starter
Eric
6.0_gearhead99's Avatar
SO my truck Idles fine, drives decent up to 1,800 rpm but above that the rpm varies and it has no power, an will not go full throttle. it tops out at 3000rpm with no power. My truck is an 05 with an egr delete, bypass coolant filter, afe stage II intake and a sct tuner. It is not studded. This was happening before and after a week of trying to find the issue I took it to the dealer and they ran a cont. balance and tested other things to find nothing more than a clogged air filter(has been replaced with new since then) which seemed to fix the problem. now it is doing it again and I have no idea what the cause is. I am going to chek my FICM later today. I just want to know what to check. Any suggestions?
6.0_gearhead99 is offline
post #2 of 35 (permalink) Old 03-15-2014, 08:04 PM Thread Starter
Eric
Re: Need help with the Diagnosys!
Well the FICM was showing 47.5 volts and the boards looked good. The truck was still acting up after I put it back together for a bit and then it started running great again. Could this be a harness problem, and where should I check for chaffed and broken wires?
THanks,
Eric
post #3 of 35 (permalink) Old 03-15-2014, 11:49 PM
Big dumb redneck
6speedSD's Avatar
Garage
Did you check voltages with KOEO, again while cranking, then again when running?
Could be harness issues. Check anywhere your harness makes contact with anything. Around where it connects to the FICM is a good start. Just follow the harness and check anywhere you think it could rub anything. Also make sure it's plugged in well too.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #4 of 35 (permalink) Old 03-16-2014, 12:13 AM
2Dstorm's Avatar
Are you getting boost?
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #5 of 35 (permalink) Old 03-16-2014, 12:15 AM
2Dstorm's Avatar
Check the ground strap on the back side if the ficm could be loose
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #6 of 35 (permalink) Old 03-19-2014, 03:54 AM Thread Starter
Eric
6speedSD, I only checked key on engine off. will try checking the other ways and the harness.
2Dstorm, where is that grounding strap supposed to run to and where where does it hook to on the FICM. From what I remember, there wasnt one when I looked at it the other day, in fact both rear bolts were missing. IS there supposed to be another plate there like the one on the front as well? right now it has a bolt with a big washer in one side of it.
post #7 of 35 (permalink) Old 03-19-2014, 11:18 AM
Fixing Broken Stuff
toolmangary's Avatar
Does it have any codes?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #8 of 35 (permalink) Old 03-19-2014, 10:12 PM Thread Starter
Eric
There are no codes, and I don't have an actual boost pressure gauge, just the one on my sct livewire TS
post #9 of 35 (permalink) Old 03-20-2014, 03:31 AM
Fixing Broken Stuff
Tell me what your EBP numbers are, KOEO, KOER,-idle
2004 Jetta TDI
1956 F100
post #10 of 35 (permalink) Old 03-20-2014, 05:06 AM Thread Starter
Eric
will get them asap
