blown intercooler hose on hot side - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-15-2014, 01:26 AM Thread Starter
Napadan's Avatar
So I found the elbow coming off the turbo had an 1 1/2" split in it. Bet that was where exhaust smell was coming from? Anyhow I noticed that there was a small amount of oil in the boots and pipe when I took them off. Is this a sign of a pending major fix? Should I start checking into how often I can donate blood to make cash quick or is it normal wear and tear. Motor has 175k now on it.
05 F250 SCLB. 75k Water filter, blue spring upgrade,Magnaflow 4" turbo back system w/muffler and SCT tuner with custom tunes by Drew.
Napadan is offline
post #2 of 9 (permalink) Old 03-15-2014, 03:05 AM
"resident smarty pants"
Re: blown intercooler hose on hot side
Oil is normal - it is from the ccv system.
oil softens the boots and they eventually split - also normal.
Mark
bismic1 is offline
post #3 of 9 (permalink) Old 03-15-2014, 03:33 AM
Administrator
Zmann's Avatar
it is true it's normal
my hotside boots weep a little oil as they always have I have 100k on them I should get some new ones
my 03 cold side metal pipe replacement for the 06 plastic pipe came with new boots so that side is done
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 9 (permalink) Old 03-15-2014, 03:56 AM Thread Starter
Napadan's Avatar
Thanks guys! Was worried turbo was leaking. Going to get the lower boot ordered too. It was a bit soft feeling when I took everything apart to inspect and clean.
Napadan is offline
post #5 of 9 (permalink) Old 03-15-2014, 04:47 PM
Administrator
Zmann's Avatar
they are slightly pricey but I need to order some also
look at out sponsor sunrise ford for 20-40% off and free shipping
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 9 (permalink) Old 03-15-2014, 05:22 PM
amdriven2liv's Avatar
I replaced mine with boots from RiffRaff Diesel.
Ford - 03-07 Super Duty 6.0L - Turbo & Related - Intercooler CAC Boots - Riffraff Diesel Performance
"I'm hitting easy street on mud tires"
amdriven2liv is offline
post #7 of 9 (permalink) Old 03-15-2014, 05:42 PM
No exhaust smell should have come from that. They are on the intake/air side of the turbo.
mattmankow is offline
post #8 of 9 (permalink) Old 03-16-2014, 12:52 AM
Big dumb redneck
6speedSD's Avatar
Garage
Exhaust smell under the hood sounds to me like a possible leaking uppipe.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #9 of 9 (permalink) Old 03-16-2014, 04:19 AM Thread Starter
Napadan's Avatar
Will have to keep chasing that exhaust smell. Was able to get a new boot from Gates through work this morning.
Napadan is offline
