Got fuel pressure hooked up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-14-2014, 03:42 AM Thread Starter
Weatherlite's Avatar
Garage
Got the Glow Shift fuel pressure sensor installed today and kept having leaking issues. I checked, re-checked, re tightened, reapplied the liquid teflon tape, etc. So, I pulled the adapter Glow Shift provided for the port and compared it to the original plug. Lo and behold, the O-rings were different sizes!! Swapped O-rings and no leaks! :)
Anyway, at idle I'm sitting at 62PSI. At WOT it drops down to 51PSI. I know those are in the ok zone. I'm just wondering if the PO did the blue spring or not. Guess I'll find out in a couple weeks when I start my projects under the hood.
Weatherlite is offline
post #2 of 3 (permalink) Old 03-14-2014, 03:54 AM
Banned
Re: Got fuel pressure hooked up
Sounds good for now.
miller45103 is offline
post #3 of 3 (permalink) Old 03-16-2014, 09:23 PM
Big dumb redneck
6speedSD's Avatar
Garage
Sounds like you already have the blue spring. I know before I installed mine I was seeing about 50ish at idle. After the spring, I was up over 60. Haven't checked it at WOT, seeing as how I never go WOT.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
