zero power after hg - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 03-13-2014, 03:52 PM Thread Starter
super pro
zero power after hg
Truck starts good idles good but has no power. Wont power brake over 1000rpm. No codes. Did hg egr delete studs powermax and afe intake. Has 60psi of fuel pressure. Is full of oil. Ficm has propper voltage. When i take it down the road it will eventually get going and build boost but doesnt have the powerit should. Checked all intercooler boots unplugged icp checked ebp please help
truckguy876 is offline
post #2 of 40 (permalink) Old 03-13-2014, 03:53 PM Thread Starter
super pro
Re: zero power after hg
Also no smoke
post #3 of 40 (permalink) Old 03-13-2014, 07:08 PM Thread Starter
super pro
post #4 of 40 (permalink) Old 03-13-2014, 07:18 PM
jfarmer86's Avatar
Did you have tunes on it before you tore it down?
jfarmer86 is offline
post #5 of 40 (permalink) Old 03-13-2014, 07:21 PM Thread Starter
super pro
No tunes before or after. Truck ran great before tear down
post #6 of 40 (permalink) Old 03-13-2014, 07:25 PM Thread Starter
super pro
Also it even revs slow while in park.
post #7 of 40 (permalink) Old 03-13-2014, 07:26 PM
jfarmer86's Avatar
Check all connectors? MAP EBP especially?
post #8 of 40 (permalink) Old 03-13-2014, 07:29 PM Thread Starter
super pro
Checked and triple checked. Checked map readings koeo and it was reading right.
post #9 of 40 (permalink) Old 03-13-2014, 07:31 PM
03fathead6.0's Avatar
fuel pressure regulator perhaps?
2003 F250 6.0, 4" on Pro Comp 35's, Twin Grand rock 6" mitre cuts set to 2" above cab, Dyno Mat cab, SCT X4, Blue spring, CCV mod, Delta tool box. And it is NEVER CLEAN
I dont walk this way because of the wounds I have suffered in the line of duty, but because my balls are just that big!
03fathead6.0 is offline
post #10 of 40 (permalink) Old 03-13-2014, 07:32 PM
jfarmer86's Avatar
Have you tried resetting the KAM? Turbo solenoid plugged in all the way? No codes? Sorry just going threw my mind process =) How far did you drive it after? Did you prime the fuel system to see if it had any air?
