Need some ideas - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-12-2014, 05:54 PM Thread Starter
Need some ideas
Hey guys, I have been a long time lurker and don't think I have ever posted. I need some help with my 2005 6.0. I have searched and read a ton, I can't seam to track down my issue. First off the truck has an egr delete and the updated STC fitting with the stand pipes and dumby plugs. I also just installed a new injector in #2 because of a contribution code. Just cleaned the turbo when I did the STC fitting. Also did the blue spring and 6.4 banjo bolts. I am running a SCT live wire programmer with 4 inch exhaust. No custom tunes
The current issue is, when I try to get into the throttle at all it bucks and acts like it's not getting fuel, I changed that injector and the truck does idle better now and at cruise seams to be smoother, but it didn't fix the bucking. It does take off like crazy now with the new injector for a second and then starts to buck again. If I am super smooth with the throttle I can get up to highway speeds,and it runs smooth down the highway, but if I get into the throttle just a little to hard it bucks and hiccups
I have check FICIM voltage and also the ICP Pressures. Both checkout good and I have also watched the scanner on the cylinder contribution codes and when it bucks it doesn't show any cylinders missing. I have also pulled the programmer and it still does the same thing just not as bad. I also just changed the fuel filters and oil not even 3,000 miles ago. My next step is to check fuel pressure at the bowl and pull the frame filter out and see what it looks like.
Thanks guys any help or ideas would be great
Bones96 is offline
post #2 of 13 (permalink) Old 03-12-2014, 06:05 PM
Wheelhop's Avatar
Re: Need some ideas
It might be worth a try to clean the tube going to your EBP sensor. If it gets sooted up, it'll cause some issues like that.
Wheelhop is offline
post #3 of 13 (permalink) Old 03-12-2014, 06:07 PM
2Dstorm's Avatar
Re: Need some ideas
It's another injector get a scan guage the sct tuners don't always pickup injector codes
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #4 of 13 (permalink) Old 03-12-2014, 06:17 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: Need some ideas
or the one you put in. Who's injector did you use?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 13 (permalink) Old 03-12-2014, 07:49 PM
2Dstorm's Avatar
Re: Need some ideas
Did you pull the rubber cap off the injector? Just saying I've done it lol
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #6 of 13 (permalink) Old 03-12-2014, 10:37 PM Thread Starter
Re: Need some ideas
Forgot to mention I cleaned the EBP sensor already and I have been using a snap~on solus scanner and that doesn't show up with more injectors. I did remove the rubber cap.
Bones96 is offline
post #7 of 13 (permalink) Old 03-12-2014, 10:38 PM Thread Starter
Re: Need some ideas
Oh and its was a reman injector right from Ford.
Bones96 is offline
post #8 of 13 (permalink) Old 03-13-2014, 01:15 AM
Re: Need some ideas
Bucking can also be from sticking turbo vanes.
lenzhotrod is offline
post #9 of 13 (permalink) Old 03-13-2014, 02:16 AM
2Dstorm's Avatar
Re: Need some ideas
Check this hose for leaks, it will cause your turbo vanes to shutter
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #10 of 13 (permalink) Old 03-13-2014, 01:15 PM Thread Starter
Re: Need some ideas
Map sensor hose checked out good, I removed the tune again this morning and it doesn't buck or seem to miss. I think I am going to barrow a friends tuner and see if it does it with his tuner in the truck. Got my extra fuel cap in yesterday also so I can make a setup to check fuel pressure.
Bones96 is offline
