Oil rule of thumb??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 03-12-2014, 02:21 AM Thread Starter
Currey's Avatar
So in reading quite a number of posts, I see what oil to use can be debated till you're blue in the face. I see some like 0w while others like 5w, or 15w...and so in and so on. Then there is the issue of what (if any) additives should you use?!
I guess what I'm asking is, is there a rule of thumb you can follow? Is there an oil that is good no matter what the application? Whether you have high or low miles, whether you pull a lot, or not at all?
I have a 2005 with almost 170k miles. I will drive it less than 5k a year. How often should I change the oil to make this engine last? And what oil should be used? Thanks!
Currey is offline
post #2 of 16 (permalink) Old 03-12-2014, 02:30 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: Oil rule of thumb???
Pepsi or Coke, but a full synthetic can help with stiction issues.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 16 (permalink) Old 03-12-2014, 04:20 PM
amdriven2liv's Avatar
I see snow, so at least a synthetic, probably 5w-40 would be fine.
5000 a year, you could end up with turbo issues down the road. Make sure your truck has the vane sweep program in it.
My truck was only used 5000 a year by the original owner and it went through 3 turbos. All from not being used.
"I'm hitting easy street on mud tires"
amdriven2liv is offline
post #4 of 16 (permalink) Old 03-12-2014, 04:26 PM
'05 Excursion
Term3's Avatar
Depending on flash version if the EGR valve is not electrically connected the PCM no longer will do the vane sweep at startup
It gets to -40C here and I use 5W40 synthetic, but I use an oil pan heater also.
Sent from AutoGuide.com App
Term3 is offline
post #5 of 16 (permalink) Old 03-12-2014, 05:15 PM Thread Starter
Currey's Avatar
Fill me in on vane sweep please. My truck is bone stock.
Currey is offline
post #6 of 16 (permalink) Old 03-12-2014, 05:17 PM
'05 Excursion
Term3's Avatar
Only applies if you have done an EGR delete.
Term3 is offline
post #7 of 16 (permalink) Old 03-12-2014, 05:19 PM Thread Starter
Currey's Avatar
I plan to in the future. Can you educate me?
Currey is offline
post #8 of 16 (permalink) Old 03-12-2014, 05:21 PM Thread Starter
Currey's Avatar
What's the flare to In Your avatar? You work at a refinery? Oil and gas field?
Currey is offline
post #9 of 16 (permalink) Old 03-12-2014, 05:26 PM
'05 Excursion
Term3's Avatar
Use to work at a refinery, now at a ethane cracker. LOT cleaner process. :)
Term3 is offline
post #10 of 16 (permalink) Old 03-12-2014, 05:35 PM Thread Starter
Currey's Avatar
I bet it is cleaner!!! We have cracker plants popping up around here in wv/pa now. I work in the Marcellus shale myself.
Currey is offline
