Birds under the hood!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 03-11-2014, 09:09 PM Thread Starter
Currey's Avatar
Got me some chirping birds under the hood so I've decided to replace the idler, tensioner pulleys, and belt - that way the only whine I hear is that of the turbo. From what I have researched, it's usually one of the two pulleys that causes the chirping. And when one goes bad, the other isn't far behind. So while I'm in there, for cheap insurance if nothing else, I'm going to replace both.
Just had some quick part number questions that I'm sure someone on here can cross reference. Got these numbers from NAPA. So here they are
Idler pulley 36329
Tensioner "assembly" 38257
Belt 25-081265
My main question is with the tensioner "assembly". My buddy that owns the local NAPA said that what came up in his computer is comprised of two pulleys. Does this sound right?
Thanks for any help!
Currey is offline
post #2 of 26 (permalink) Old 03-11-2014, 09:26 PM
San Juan Cowboy
OilHammer's Avatar
Re: Birds under the hood!!!
Idler pulley 36329
Belt 25-081265
You don't happen to have a video of what that sounds like do ya? I'm trying to track down something similiar and would love to rule these out.
OilHammer is offline
post #3 of 26 (permalink) Old 03-11-2014, 09:37 PM Thread Starter
Currey's Avatar
Sorry, I do not. At first, it was justin a cold start. Then it was when I got on the throttle - the more throttle, more chirping. Now it's that, plus at idle. Pretty common problem from what I've gathered.
Currey is offline
post #4 of 26 (permalink) Old 03-11-2014, 09:57 PM
San Juan Cowboy
OilHammer's Avatar
That sounds alot like what I'm dealing with...
post #5 of 26 (permalink) Old 03-12-2014, 01:24 PM
I just replace the bearings in the idler and tensioner pullies. Press the old one out, press the new one in. Cost less than $3.50 each.
lenzhotrod is offline
post #6 of 26 (permalink) Old 03-12-2014, 01:28 PM Thread Starter
Currey's Avatar
Sounds simple enough! Excuse my ignorance on the issue, but does that take any certain kind of too? A press maybe? You have piqued my interest!
Currey is offline
post #7 of 26 (permalink) Old 03-12-2014, 01:29 PM Thread Starter
Currey's Avatar
Also, do you have a P/N for the bearings?
Currey is offline
post #8 of 26 (permalink) Old 03-12-2014, 01:59 PM
Fixing Broken Stuff
toolmangary's Avatar
I think it's a 203FF
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #9 of 26 (permalink) Old 03-12-2014, 02:13 PM Thread Starter
Currey's Avatar
Same for all of the pulleys? Also, how bout removal and installation? Any special tools needed?
Currey is offline
post #10 of 26 (permalink) Old 03-12-2014, 02:42 PM
Fixing Broken Stuff
That 203FF fit about 90% of all vehicles. about the only tools you need is a hammer, some sockets to drive the bear out and a vise helps. Around here the chinese bearings are about $3.50 and the good quality are $7-8
2004 Jetta TDI
1956 F100
