bent valve? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-10-2014, 02:57 PM Thread Starter
super pro
bent valve?
Long story short did hg and studs. Started up and its was popping through intake. Took valve covers off and found a broken in half rocker and its pushrod bent into a u. I get that its probably my fault and the push rod probably wasnt in lifter corretly. Question is what are the chances i bent a valve.. kinda just need someone to tell me everything will be ok...lol..
truckguy876 is offline
post #2 of 6 (permalink) Old 03-10-2014, 03:06 PM
Re: bent valve?
more than likely you just effed up the rocker and push rod. Its good practice to turn the motor over by hand a good few revolutions to ensure you dont have a mishap like that. Install the new parts and see how it runs, im sure its ok.
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #3 of 6 (permalink) Old 03-10-2014, 03:51 PM
Re: bent valve?
Just run pressure on that cylinder(with valves closed) thru the glow plug hole.
lenzhotrod is offline
post #4 of 6 (permalink) Old 03-10-2014, 05:59 PM Thread Starter
super pro
Re: bent valve?
I was gonna run comp check on that cylinder but dont have the adapter.. all my stuff is for the semis. Guess im just gonna put it together and see what happens
post #5 of 6 (permalink) Old 03-10-2014, 06:12 PM
Re: bent valve?
Just remove the glow plug and use a rubber tipped air nozzle!!!! Not rocket science.
post #6 of 6 (permalink) Old 03-10-2014, 06:20 PM Thread Starter
super pro
Re: bent valve?
10/4
