Another No Start 6.0 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 03-10-2014, 01:14 AM Thread Starter
Well came home last night, parked up and now no start in the morning. Checked fuel cup, it was full. pulled oil filter and sming engine, cup filled up. using my edge insight i geth the following readings: FCIM 47.5V, ICP psi reading at 275. Engine swings strong but not start. Only code is PO657 but its been ther for over three months please help.
oh its an 06 f250 lariat fx4 with about 203,334 miles. our temp in the Caribbean is like 82 dergress
Churchboy 6.0 is offline
post #2 of 18 (permalink) Old 03-10-2014, 10:52 AM Thread Starter
Re: Another No Start 6.0
Any help. Some one any one. Pleaseee
post #3 of 18 (permalink) Old 03-10-2014, 11:11 AM
Jackleg Mechanic
mastrkee's Avatar
That icp has to be 500 or more to start. You either have a bad sensor or regulator or a internal hpo leak. Did you unplug the icp and try starting it?
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #4 of 18 (permalink) Old 03-10-2014, 11:13 AM
"resident smarty pants"
If you do not get more than 275 psi ICP when cranking, then you most likely have a leak. Have you tried cranking w/ the OCP unplugged? Have you done an air pressure test of the HPO system?
Do you know if the fitting off of the HPOP (the STC fitting) has ever been replaced?
(edit - I guess I am a little slow this AM - lol)
Mark
bismic1 is offline
post #5 of 18 (permalink) Old 03-10-2014, 12:00 PM Thread Starter
Unplugged it this morning and the icp psi was 1286 but still no start.
post #6 of 18 (permalink) Old 03-10-2014, 09:06 PM
Jackleg Mechanic
mastrkee's Avatar
With it unplugged the pcm couldn't get a reading so it made one up in an effort to start itself. That was a way to test the sensor. That was not you psi, you have an internal leak and will need to air test it or just buy and replace all the known trouble spots. One or more of them is likely the culprit. They are the STC fitting, stand pipes and dummy plugs. Also a faulty IPR is a less likely candidate but should be examined as well.
Jeff
mastrkee is offline
post #7 of 18 (permalink) Old 03-10-2014, 09:30 PM Thread Starter
would I need to replace the HPOP Also. How hard is it to replace the above parts.
post #8 of 18 (permalink) Old 03-10-2014, 10:15 PM
Jackleg Mechanic
mastrkee's Avatar
If an air test doesn't indicate a leak then the hpop would be suspect. Is there any chance you could get it hooked up to a scan tool, like AE or some other diagnostic tool?
Jeff
mastrkee is offline
post #9 of 18 (permalink) Old 03-10-2014, 10:17 PM
being that it is a 2006 my, your HPOP is most likely just fine.
Mark
bismic1 is offline
post #10 of 18 (permalink) Old 03-10-2014, 11:19 PM Thread Starter
i don't hve acess to a compressor. so i cant do the air test. the only scan tool i hve is from palmer performance engineerin. i bought it when i had my dodgeee.
quick question; should i change my oil cooler and do an egr delete since im goin in there, just a thought. don't know if it was ever done. bought he truck used over a year and six months. had 194566 mile when i bought it so im not too sure as to all hat has been done to it. my deltas are at the most 4 degress apart but my temps run like from 198 - 204 degres acording to my edge insight. i dont hve any tunes and just replace radiator n temostat about 3 moths ago
