6.0 Injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-07-2009, 04:18 AM Thread Starter
6.0 Injectors
Is there a difference between a 03 injector and a 05 injector. In other words will a 03 injector work in an 05?
j350_05 is offline
post #2 of 10 (permalink) Old 02-07-2009, 04:18 AM
Abrannan19's Avatar
Re: 6.0 Injectors
yes an 03 injector will work in an 05
Abrannan19 is offline
post #3 of 10 (permalink) Old 02-07-2009, 04:23 AM Thread Starter
Re: 6.0 Injectors
Well we put 4 new injectors in today in 1,3,5,7 and the box had 03 on it. The truck ran fine for about 20 min and the on the test drive it died and has white smoke and diesel coming out of the tail pipe. Now on the IDS all of them show as bad injectors why is this?
j350_05 is offline
post #4 of 10 (permalink) Old 02-07-2009, 01:12 PM
Village Idiot
LRTMatt's Avatar
Re: 6.0 Injectors
Sounds like you have a bad FICM. There is a remote possiblity that it's a wiring issue, but with the whole right bank coming up bad, I would suspect the FICM. Check the harness connectors on the bottom of the FICM first to make sure they are all connected tight.
LRTMatt is offline
post #5 of 10 (permalink) Old 02-07-2009, 02:11 PM
Slacker
Evil Eye's Avatar
Re: 6.0 Injectors
I would agree to check the FICM wiring, but they have two connectors with different sequences of numbers to help you diagnose a wiring/FICM problem.
Here is a LINK to some more information, but if the FICM were bad, you would get everything on one bank showing as bad (2, 3, 5, and 8) or (1, 4, 6, and 7).
Shawn Carlson
Proud Navy Vet
2005 F250, CC, 6.0 PSD, FX4
(The Sweet Unit)
Evil Eye is offline
post #6 of 10 (permalink) Old 02-07-2009, 04:41 PM
2Cruel
moremph's Avatar
Re: 6.0 Injectors
Thier is diffrences in 03, 04 and 05 injectors, Swamp was telling me about em but i cant remember the break down, I do knoww that you should not use some of each, they need to be used in a complete set
Call Jon or Dave at www.swampsdiesel.com
MPH Enterprises
2L Motorsports
SWAMPS Extreme Powerstroke Performance
Powerstroke Everywhere
moremph is offline
post #7 of 10 (permalink) Old 02-07-2009, 05:47 PM
bring the chain
kyle43335's Avatar
Re: 6.0 Injectors
only use the injectors from other years in sets of eight output is different
kyle43335 is offline
post #8 of 10 (permalink) Old 02-07-2009, 06:41 PM
Village Idiot
LRTMatt's Avatar
Re: 6.0 Injectors
I agree with injectors being matched up but if your 03 has 2 bad injectors, Ford will only replace those 2. The replacements are not going to be C-94s either. Is there really that much difference in the output? I know a guy that has like 5 of his stock C-94s and 3 replacements and the freakin truck runs 13.4s on fuel and 12.2s on spray. I guess somebody forgot to tell his injectors that they won't work together.
LRTMatt is offline
post #9 of 10 (permalink) Old 02-18-2009, 04:29 AM Thread Starter
Smile Re: 6.0 Injectors
Ok here was the deal they replaced the right side with an 03's injectors. That would not work they all went dead after about 1 mile. Put in new oneS and the truck ran great for two days. Now they replaced the other side and it drives like a new truck. LOTS OF POWER NOW!!!!!
j350_05 is offline
post #10 of 10 (permalink) Old 02-18-2009, 02:40 PM
Re: 6.0 Injectors
Glad to hear you got it fixed finally!
04 F250 FX4 CC SB 6.0 PSD Torqshift
Exhaust, RCD 62mm, 155/75 Injectors, PCM & FICM tuned by Eric, EGR Delete, ARPs, Dashdaq, Banks Intercooler
kruser02 is offline
