Update SCT Liveload Software - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 18 (permalink) Old 02-13-2009, 01:19 AM
Re: Update SCT Liveload Software
can this be used on the sf3
hot redhead is offline
post #12 of 18 (permalink) Old 08-29-2009, 01:10 AM
Thank you!
jerseymike68 is offline
post #13 of 18 (permalink) Old 02-14-2010, 05:00 PM
I have the sct and am unfamilier with how to download these costum tunes on it. Could you walk me through it and I noticed in the other post's that you have to return it to stock first. By doing this, just to confirm, you will not delete your stock tunes. Thanks for the help
ryanthomas330 is offline
post #14 of 18 (permalink) Old 03-28-2011, 02:16 PM
locomike's Avatar
I HIGHLY RECOMMEND AGAIST A FIRMWARE UPDATE AT THIS POINT !!!!
BEWARE of SCT 6.0 Flash
Truck running great? Think you may wanna 'tinker' with it to get a little more power or fuel mileage ? BEWARE of what "COULD" happen. Although I am sure there are 1000's of users who have successfuly used this with good results just beware of what can happen. It seems SCT is having 'firmware issues' in their products. Most of their dealers will give you a heads up to this and advise you DO NOT UPDATE your firmware. If you DO DECIDE to update your firmware and perform a tunes download I suggest you be sitting outside a FORD service garage. BECAUSE THE UNIT CAN NOT RETURN THE TRUCK TO STOCK. SCT dismall customer support will eat your time like Washington eats our tax dollars. Eventually the will blame it on your 'faulty' ECM (truck computer) that was running perfectly before they abandone you and no longer take your calls. I BLAME MYSELF for tinkering with an amazing running machine. To 'laugh at myself' I started this website so we can all have a pity party
SCT KILLED MY FORD victims site....................
Scepticle of this ? I suggest you GOOGLE the following words in any combination:
SCT ECU FRIED
SCT PCM FRIED
SCT ECU DAMAGE
SCT PCU DAMAGE
SCT PROGRAM FAIL
SCT FORD DAMAGE
Crew Cab Short Bed,2003 early build 6.0
EGR Delete Manifold from FCDP
CCV Reroute from LOWES
FICM custom program from IDP
SCT custom tunes from IDP
EDGE Insight with EGT
BB mod to the FPR
35" tires (no lift) yeah it's tricky,2" aluminum spacers
ARP Head Studs
Black ONYX Head Gaskets
Mishimoto MMRAD-F2D-03 Performance Radiator
locomike is offline
post #15 of 18 (permalink) Old 02-01-2012, 01:24 AM
put an EGR delete cold air intake turbo back dyno flow exhaust ordered and SCT tuner to clear the check engine light my question is "is there a setting to turn off the sensor so the light does not come back on?"
bamajon is offline
post #16 of 18 (permalink) Old 02-01-2012, 01:34 AM
Yes... did you get gauges? And custom tunes?
patrickke is offline
post #17 of 18 (permalink) Old 10-07-2016, 04:11 AM
Does anyone else have an issue where trying to use the data logging function. Before hand oyu let it scan for what I assume are all possible PIDS and it takes forever and sometimes times out?
- Pete
LittlePete is offline
post #18 of 18 (permalink) Old 07-02-2018, 06:54 AM
JonesY's6.0's Avatar
I have a 06 6.0 and i was running the sct livewire ts+ and i wanted to change options on my tune and i returned it to stock and tried to program my truck i got a 110be code and its a fail to upload . well i called sct and did all there checks and everything they wanted me to and they told me my stock programing was not all there and they needed to redo the stock program and i was shocked cause i used this tuner for 5 months no issues after the new stock program they uploaded on my tuner i tried to tune my truck back to stock . well with no luck and another code 110dd and i called sct tech line back and they were looking at the strategy and now they told me my tuner will not unlock my truck and that was friday and waited for there call back but it was close to end of business for them and i did not hear anything yet but hope to monday morning cause i cant do anything with my truck and it was perfectly fine and i should not have did any updates on my tuner and just left it be cuz now until they or i figure out what happened i. Dont know what to do .i checked all fuses relays and grounds and if anybody has any information or that can and are willing to help another prowerstroke owner out id greatly appreciate it
JonesY's6.0 is offline
