450 gear vendor overdrive - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.4L Power Stroke - Aftermarket & Performance
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 04-11-2011, 12:42 PM
donzimama
Offline
Banned
Member's Gallery
Wink 450 gear vendor overdrive
Has anyone used this on a 4.88 450? Ol larry is getting murdered on economy with no deletes still and 4.88s don't help. Any input appreciated
Reply With Quote Quick reply to this message Go to the top
Old 04-11-2011, 03:58 PM
tbsimmons's Avatar
tbsimmons
Offline
Newbie
Member's Gallery
Re: 450 gear vendor overdrive
I will be watching this thread, as I have a 450 with 4.88's and mileage is still on the low side.
I would like the same mileage I get doing 60 at 75, which the gear vendor would do it.
__________________
2008 F450 4x4
Stock
  #3
Old 04-11-2011, 04:28 PM
LovinPSDs's Avatar
LovinPSDs
Offline
Member's Gallery
Bigger tires, FTW!!
__________________
2008 F350 SRW CCLB King Ranch - 4.5" Icon, 37's, IDP Tunes, AFE, 4" Turbo back Flo Pro, tranny fixed by Elite
  #4
Old 04-11-2011, 04:36 PM
Red Stroke
Offline
Member's Gallery
delete, delete, its alot cheaper than a GV.
I am running 3.73s with mine and it help mileage some 70 at 1450 rpms..
I would say your application would net better numbers than mine..
__________________
White 01 Superduty, Ex-Cab SB, 4x4, Built 12V Cummins, HTS Billet 47RH, 8" Stack, 796 HP 1300 ft/lbs #2, 1374 HP 2500+ ft/lb on the gas.
What you don't measure, you can't control. What you can't control-you can't improve.
  #5
Old 04-11-2011, 04:40 PM
erikclaw's Avatar
erikclaw
Offline
Member's Gallery
I think it would be the best for you guys with the 4.88's and factory tires . Should really reduce the rpm's when cruising and have the ratio needed to get the big loads rolling from a start.
__________________
2012 DPC Campion
2008 King Ranch CC 6.4 Elites Stage 2 ported heads, stage one cam, ported intake, HP and LP fuel systems. Dragon Fire HPFP, HP compounds, EGR delete with dual wastegates, 85 hp injectors, CFM elbow, EDE race trans, 6.0L ported manifolds, tuned by Eric @IDP
  #6
Old 04-11-2011, 04:46 PM
LovinPSDs's Avatar
LovinPSDs
Offline
Member's Gallery
Are the trucks stock? With a modded truck re gearing and still getting the load rolling shouldn't be a problem, these trucks can make a boat load of power. Seriously tho.. If you can throw a bigger tire on it, it'll bring the ratio down some.
  #7
Old 04-11-2011, 04:48 PM
erikclaw's Avatar
erikclaw
Offline
Member's Gallery
I took it as they are still stock, since the nothing was deleted.
  #8
Old 04-11-2011, 04:49 PM
donzimama
Offline
Banned
Member's Gallery
It's still stock. It does not lack power. At 70 it's doing 2450 and 9 mpg. Oh yeah don't want bigger
Tires because speedo has to stay accurate. When we tote the bote the trailer is too wide to run without a dot number and a lot of paperwork to be oversize. Not to mention laying out every route. So getting stopped for speeding is not an option lol.
  #9
Old 04-11-2011, 04:53 PM
LovinPSDs's Avatar
LovinPSDs
Offline
Member's Gallery
Shoot I would mod that puppy.. thats cheaper than a GV and good for mileage, pleasure and better towing...
If you are lookin to stay all stock then I don't know the exact answer for gears.. sorry.
  #10
Old 04-11-2011, 04:55 PM
donzimama
Offline
Banned
Member's Gallery
Definitely deleting and tuning. Just looking for that extra gear for 75 cruising without worrying about water pump cavitation from
High rpms.
  #11
Old 04-11-2011, 05:00 PM
bubbamcnasty
Offline
Member's Gallery
you can't tow with a gear vendor's and a diesel....you can only run it empty
i called them, this is the answer I got.
  #12
LovinPSDs's Avatar
LovinPSDs
Offline
Member's Gallery
If your going to mod it I would gear down. These trucks have tons of power to get anything rolling.. Erikclaw has a similar thread going about gearing down also.
How big do you tow?
Our 350 dually with 4.10's stock moves our 16K equipment trailer no problem but I do feel it falls on it's face a bit at the upper speeds. This is mostly because i'm use to my extreme street tuned truck I think. I have pulled it with the 150 tune before tho and it was great. I bet someone could make you a pretty badass tow tune depending on how heavy your total weight is. The tune size will also depend on how much you wanna mod.. the more you do to keep temps down the more fuel/power you can tow with.
  #13
Old 04-11-2011, 05:19 PM
donzimama
Offline
Banned
Member's Gallery
8500lb dry hull, 350x5lb = another 1000ish in fuel on boat, another 2k in bs on the boat easy plus trailer =12,500 +
  #14
Old 04-11-2011, 11:01 PM
Sahrens0202's Avatar
Sahrens0202
Offline
Member's Gallery
You serious? That stinks!!
__________________
2008 Job2 F-350 King Ranch cclb, Spartan,KEM,Banks,cai mod., powerstroker67s 4in Ceramic coated downpipe, 5in black mitre cut tip and bov from Rudy's
RCD cac pipe,MPD's billet ccv block,Recon,Retro 6k heads and fog's,
  #15
Old 04-11-2011, 11:24 PM
erikclaw's Avatar
erikclaw
Offline
Member's Gallery
That is what I thought too. They need to fix that.
  #16
Old 04-12-2011, 01:09 AM
Heavyhaul's Avatar
Heavyhaul
Offline
< Chuck Norris approved!
Member's Gallery
You can tow with the GV. I have alot of miles on mine towing and unloaded. Check the facts at GV website. 30,000 GCVW. If you haul constant and commercal they only recommed 25,000 GCVW and a HD cooler. Its lower just to extend the life of the unit it reads. I average 30,000 lbs when I tow. I would only recommend towing with the 4.88 on a stock motor. You will need more power to tow with the 4.30. The only thing is you have to disengage the unit when your going down hill using engine retarding. It will burn the clutch in it. It also takes some learning to shift it with a auto. We have two trucks with them and they have been great.
FYI:I would also add the new 2011 6 speed autos are double od already. So no need for it in your next truck.
__________________
2008 F450 Lariat CC
H&S Black Maxx,Exhaust delete,Custom air inlet,Custom cold side intercooler tube,Banks intake,Banks Intercooler,Gear vender 2 speed,60 gallon replacement fuel tank,EDE Head studs,Rudys EGR delete w/ wastegate, downpipe, II Turbos,II dragon fire pump, Empire 40% over injectors, Air Dog 165 w upgrade, Ported intake manifold.
  #17
Old 04-12-2011, 10:03 PM
Sahrens0202
Offline
Member's Gallery
Thanks man!
  #18
Old 04-12-2011, 11:31 PM
jockeyboy
Offline
Member's Gallery
I have an 08 F450 with 4.88 gears before I would only get 9MPG I tuned and deleted and now I get 17.5 to 20MPG "empty" depending on how I drive it. Running 70MPH I am usually around 2400 to 2600 RPM's I would like to drop my gearing also I think that would help out with MPG's But I am holding off cause I have a set of American Force 22.5's in my line of sight and after they are on the truck wait and see how I am looking RPM wise
  #19
Old 04-13-2011, 12:30 AM
Black086.4's Avatar
Black086.4
Offline
Member's Gallery
Don't the 450's throw a code of overspeeding at 70mph
__________________
2008 F350 CCSB Lariat FX4 diesel-S&B intake, AFE 4" turbo back exhaust, Spartan 350, Elite studs and EGR delete w/wastegate.
2002 Tahoe 33' toy hauler
2009 Polaris sportsman 850
2011 Polaris RZR 800 Turbo
2001 Arctic cat 1M 800
2004 Arctic cat 1M 900
  #20
Old 04-13-2011, 01:40 AM
donzimama
Offline
Banned
Member's Gallery
No
Definitely not
  #21
Old 04-13-2011, 02:05 AM
erikclaw's Avatar
erikclaw
Offline
Member's Gallery
Is this hand calculated or from the lie o meter?
  #22
Old 04-13-2011, 05:24 AM
Heavyhaul's Avatar
Heavyhaul
Offline
Member's Gallery
It would throw a code at 83. The crusie would only set at 79. Kept me out of tickets for awhile now.
It has to be the lie o meter. I can only get 15 -16 at that speed w/ the gear vender and 4.30 gears. The truck weighs 10,000 empty for goodness sake.
  #23
Old 04-13-2011, 05:27 AM
erikclaw's Avatar
erikclaw
Offline
Member's Gallery
Is that all? I was thinking that I can't get that good of mileage from a stock setup.
  #24
Old 04-13-2011, 05:37 AM
Heavyhaul's Avatar
Heavyhaul
Offline
Member's Gallery
You have to be in the flats to get that. There better not be a hill in site! Not to mention you have to do a whole tank non stop. My super meter reads 24mpg.
  #25
Old 04-13-2011, 06:59 AM
stdcabFords's Avatar
stdcabFords
Offline
Built without your taxes
Member's Gallery
Send a message via MSN to stdcabFords Send a message via Yahoo to stdcabFords
A little off topic, but wasn't 08 the last year for the 4.88 gearing?
__________________
95 F250 7.3 5sp 4x4 std cab long bed
D60, RDS stage1 160's, K&N air/oil, SB single disc,glowshift-pyro,boost,fuel press,and autometer-hpop press. tunes by????
Originally Posted by Chillin View Post
The way it comes out of the hole all up IN the spray in the first video above screams HOLY TRANSMISSION BATMAN....
  #26
Old 04-13-2011, 12:09 PM
qcfarmer's Avatar
qcfarmer
Offline
Member's Gallery
Send a message via Skype™ to qcfarmer
I have an 08 with 4.88's and a spartan set on 250 all the time. Yesterday I was hauling a 16,000-17,000 lbs tractor through some nice rolling hills. I was doing 65 mph the entire time and was able to hold and even accelerate to pass on the inclines. Mind you the clutch would slip when accelerating. I didn't calculate milage but even at 8 mpg, it outperforms any other truck in those conditions
__________________
2008 F-450, 6-spd, Spartan DD, Powerstroker67 DPF/CAT delete.
1997 F-250 PSD, SB Ex Cab, 5 spd, Open intake, 3" downpipe, 5" single turnout stack, DIY Stage 1's, T.E. modded HPOP, Tuned by Tony, 4" lift, D60- SOLD
  #27
Old 04-13-2011, 12:35 PM
WoodBoy's Avatar
WoodBoy
Offline
StackinChipsLikePringles
Member's Gallery
Send a message via Skype™ to WoodBoy
If 4.88s are too low for fuel mileage i would drop to 4.30s.. It wont help a whole whole lot but it will a little.. Hard to expect 15mpg out of a #10k truck turning upwards of 2k rpm nearly all the time
__________________
2010 F250.. Stock looking
What is right is not always popular, and what is popular is not always right.
  #28
Old 04-13-2011, 12:57 PM
tbsimmons's Avatar
tbsimmons
Offline
Newbie
Member's Gallery
Lie-O-Meter.
The best I have got out of my truck is right under 17. That is cruise at 60 on the highway and maybe 4 stops. The dash in my truck is off about 1-1.5 MPG. Seems to be getting closer though.
For towing, 4.88's are great, I love them. Unloaded they suck.
  #29
Old 04-13-2011, 03:14 PM
tbsimmons's Avatar
tbsimmons
Offline
Newbie
Member's Gallery
Not enough of a drop. My brother had a 450 with 4.30's. He got 1 mpg better than me all the time, loaded or not. Not enough for me to change.
  #30
Old 04-13-2011, 09:19 PM
qcfarmer's Avatar
qcfarmer
Offline
Member's Gallery
About tire size... I already went to a 245. Will a 265 fit without a lift?
  #31
Old 04-14-2011, 04:48 AM
Heavyhaul's Avatar
Heavyhaul
Offline
Member's Gallery
The 4.88 with the gv at 75 is 2150 or 2200. Its a 500 rpm drop. Its hard to beat on the empty side and still have the gears to pull the hills when you dont need it. The 4.30 is another 150 below that if I remember right. I have two friends now that just bought new trucks and want to sell there units. one is sold to a guy here and the other one just came up. Same price. Again you cant really tow stock with 4.30s and the gv. 4.88 is the key for stock trucks.
Gear vender aux trans - PowerStrokeNation
  #32
Old 04-20-2011, 06:16 PM
CamTom12's Avatar
CamTom12
Offline
Member's Gallery
width/profile Rim size:
245 to 265 is 20mm wider. What's the profile you want to run?
like 295/65 R18
__________________
2008 F250 CCSB FX4
DPF/DOC Delete, Spartan, Banks (previous owner installed crap) Intake and Cat-back, OUO Traction Bars, 40gal TFI Tank/Toolbox, EDE Studs, HG's, and EGR Delete w/ wastegate
1969 F250 RCLB Highboy
360/4-speed
  #33
Old 04-20-2011, 06:51 PM
kyle43335's Avatar
kyle43335
Offline
bring the chain
Member's Gallery
High rpms.
a friend of mine went through 4 of those units. 4.88 gears and a lot of weight. truck weighs 11.000,the trailer and load weighs16.500. those gv units dont play well with alot of weight. he removed it.
  #34
Old 04-20-2011, 07:04 PM
BFD99's Avatar
BFD99
Offline
The Stig
Member's Gallery
Send a message via AIM to BFD99 Send a message via MSN to BFD99
That's about what our 36ft Eliminator Daytona Weighs, maybe a bit more, considering its got a super built Extreme Triple Dually Trailer on it, the F350 Dually does just fine!
__________________
2006 Ram 5.9L 2wd Gogodiesel, Garmon's Diesel
2010 Dually 6.4L, Gogodiesel, KEM Tuned
  #35
Old 04-20-2011, 07:28 PM
97singlecab's Avatar
97singlecab
Offline
Sponsor
Member's Gallery
We have installed alot of gearvendors on trucks with great success. Knocks 500 rpm out of em like heavy haul stated. I just did an 08 F550 with a gear vendors and a dpf delete with Kem tuning. Haven't heard from him on what mpg increases yet, but he is very happy with how the truck runs and pulls his fifth wheel now.
__________________
Mike Haller
Haller's Repair (307) 778-8880
shop@hallersrepair.com
RUNNIN BROKE RACING
Now offering mobile dyno services. Call today to set up your next event or get together.
  #36
Old 05-01-2011, 08:50 PM
onebadf150
Offline
Member's Gallery
I have a gear vendor for sale with low miles on it that came off of a 5R110 in my 6.0l when I sold it. I will take pics and send them to you.
Human Verification
(View-All Members who have read this thread : 229
02BigD, 03sixspeed, 04smokeman, 07strokerftw, 08BIGRIG, 08SUPERKING, 09f250jettech, 09hd6.4, 16yrenthusiest, 31 YNOT, 4x4freak, 500pilot, 6.0 p-stroke, 6.4stroker08, 6.4StrokerTN, 7.3diesel94, 94.5 Stroker, 96centurion, 97singlecab, 99.5crewstroke, ACFarmer, Adamsred08, addison, AKf250, akozman, Al Mighty, Arctic Fox, ARS267, austin229, barnhartal, Bartman, BCB, bckcx2, Beans71086, bentley, BFD99, Big Papa 03 dually, bigastrk, BigBluediesel08, BigIslandBoy, BigKid, bigmick, Black086.4, BlackBettyzPimp, Blcksmk08, blueoval, Borncountryboy, Brahmus, Brain's 97 Diesel, branden250, brickhead, brooksfruge, bubbamcnasty, Built4tq, CamTom12, CATERPILLARD11T, cbienlein, ccmac, CGCBandit, CGMKCM, chodifer, chris1978, chuckarm, CLASSICIDI, clayc_989, cluster007, Country, CPOSharkey, Craig@MPD, Cutting-Edge Diesel, daryl4412, Deereman4020, deezeljunky, desertwheeler, Diver86er, Doc_Ron, donzimama, drservo, dstryr, Dudley Glass, DylanJ, eastern, eric.davis, erikclaw, EvilTwins, f-450coalroller, f250rollinon37s, F350CCSB, fbilly420, footlong70, ford7.3sd, Fordfreak4life, Ft.Mac.F350, fuekear, fvrpowerstroke, GAM, Gollonbait, gracing, Grim Reaper, Haller, harleysdontbitc, harrison, HD-tech-NH, Heavyhaul, HoosierHick, Ipkyss, ISUsuperduty, Ithumpwheniwalk, Jared @ RiceFamilyFarmInc, Jason84, jb903, jdgleason, jess, JESTERxHEAD, jgon08, jhaddox, jjjblanc, jockeyboy, joe22790, jonathan734, jonnysteals, jt720, KansasStroker, Kevin949, Khemosabe, KR69IDI, kupaa, kyle43335, lil o rinny, lildevil02, LILGSX, LovinPSDs, lowbedriver, lubeowner, MADMAN36, MahdeyS, maps, Mark55303, mattman90, maverick347, Michigan37, MidTennPSD, moremph, Mpoage, MrMike06, my79f, Nadler, nastyf250@yahoo.com, nastystroke04, nickersonf350, nicktb, Nixon, NotStock, okiecoyote, Oliver, onebadf150, OOWeaver68, opieg01, patrickke, pmf608, pog, powerstrokeshane, Preems14, PrvnTough, PSDEng, psdguy08, PunisherGT3, qcfarmer, randylamarr, Ray82470, rbunk350, Red Stroke, redracer62, redx, red_93_l, RockinJW, Ronin, Ross01, rpm-inc, sacu, Sahrens0202, Schmidtty's F-450, scott2001, sdp-1, Semperfidoordie, Sequential6.4L, SKIRK, slayer7712, SLO DZL, slowmans, SouthFlstrokin', SpartanDieselTech, Spiderex109, stdcabFords, stevestroke08, Stout, strokin20, strokingkid1392, suban, SUPERSTROKED, switchmode, talon932, taylorfettig, tbsimmons, TERRCO, tlbailes, ToddPSD, tophertx, TravisT, TripleE44, tsatrooper, Twisted Excursion, uga33, UNCOOL, UpholsteryNoah, vader's fury, VixF450, vstahl, weekendwarriorfsw32, white7.3, White_monster, wint, WoodBoy
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
