Back up sensor staying off. - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 03-31-2011, 12:58 PM
Mooring Product's Avatar
Mooring Product
Offline
Member's Gallery
light on switch stays on indicating switch turned off, won't turn on by pushing.
Do I have a bad sensor? Fuse?
Did a search but didn't find any help..
__________________
Pete
2003 F250 FX4 Lariat Crew Cab
No Spray, No Lay...
Custom tuned and sponsored by GoGo Diesel.
Speed never killed anyone; suddenly becoming stationary... that's what gets you. Jeremy Clarkson. Top Gear.
Mooring Products Worldwide
Reply With Quote Quick reply to this message Go to the top
Old 03-31-2011, 02:57 PM
F350F351's Avatar
F350F351
Offline
Member's Gallery
Re: Back up sensor staying off.
Mine is doing that as well. Haven't had a chance to troubleshoot it.
what little info I found stated that there maybe a short in the system. can anyone confirm?
__________________
"F350, F351. Whatever it takes"
  #3
Old 03-31-2011, 03:07 PM
Mooring Product
Offline
Member's Gallery
I have read that one sensor could be bad causing the system to turn off. I can't find a fuse for it either.
Anyone?
  #4
Old 03-31-2011, 05:31 PM
blownpickup
Offline
Member's Gallery
My 03 Superduty is doing the same. Sure hope someone chimes in!
  #5
Old 03-31-2011, 06:59 PM
NYC F-350
Offline
Member's Gallery
Set your e-brake, stick the truck in reverse. Hop out and stick your ear close to each sensor on the bumper.
Listen...if you hear a rapid succession of click click click...that sensor is good. The quiet one or the slow click......click....click is the bad sensor.
If none of them make a noise, look into wiring issues
  #6
Old 03-31-2011, 08:11 PM
F350F351's Avatar
F350F351
Offline
Member's Gallery
can you be trusted NYC
I guess you did say to set the e-brake.... (I kid)
Thanks for the tip!
  #7
Old 03-31-2011, 11:19 PM
yeehaw
Offline
Banned
Member's Gallery
Send a message via AIM to yeehaw
mine was a broken power wire, or else one bad sensor could shut the system off
  #8
Old 03-31-2011, 11:24 PM
Cajunhunter67's Avatar
Cajunhunter67
Offline
PSN Been daer dun it!
Member's Gallery
Take the Ebrake off...If the bumper tags you in the head....The transmission is working properly!!! !
__________________
FORD! Because its the only Option!!!
2008 F250. SCT Livewire Erics tunes. 4 in diamond Eye exhaust. AFE intake. EGR delete, 2.5inch Ready lift SST, 20inch Fuel Throttle wheels, 35in Toyo Mt. Amp Research Steps
  #9
Old 03-31-2011, 11:26 PM
Cajunhunter67
Offline
Member's Gallery
Actually...I will be checking mine also. It will not stay in the on position. Light will go out when pushed...but as soon as I put it in reverse...the off light comes on!!
  #10
Old 03-31-2011, 11:27 PM
yeehaw
Offline
Banned
Member's Gallery
the harness goes on the left of the spare if i remember right, just pull it out of the loom
Human Verification
(View-All Members who have read this thread : 92
06 stroker, 06powerstroke, 1ststroke, 60POWERSTROKE73, 91turbogsx, 997.3PSD, BCPSD, BFD99, BigBoy6.0, bigdaddy60, Bigdog, birdmayon, blacksmoke7.3stroker, blownpickup, BPR83, buggut, bustednuckles, Cajunhunter67, Cjdorsey26, clucas6308, Cspencer225, D-bass, damnjunior, DeereMan83, dfulcher, Dieselboy740, Dustball8504, emailinnh, ericyr6, F350F351, FanofAllDiesels, fdny136, gaf350, gespur, hawgdoctor, HiVoltage, hunter441950, huntersk2k5, IIvonnyII, irontx25, janvo, Jeff Severe, Jeremy, joshua5438, justintimemoto, kfletcher, Killer48, Land6577, LOOSEWHEEL, mack7.3, MattS0273, matts05f250sd, Mooring Product, Motownfire, Mpoage, MT Pockets, NYC F-350, Pabalab, PaisteDriver, powerstroke742008, powr2stroke, puffen:D, randyhoing, redhors66, ricg, sabola1, shadow6.0, sirkdev, SixInARow, SouthFlstrokin', sschwindt, ssduck30, staffcurtis, star73, stoneage, str8wkd, TARM, tcredfish, thedynoguy, tmanrose2007, ToMorrow44, Trgoes, tsedsell, turbie, turbom700, Turd-250, wackum, xsfpns, xxmartinxx, yeehaw, Zmann
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
