Just wondering if anyone stores a belt on there truck around the top rad hose for they dont have to take the hose off on the side of the road to replace the belt. I strapped it to the tire iron and jack crank handles folded a couple of times. if you have pictures it would be good. thanks
I wouldn't wrap it around the radiator hose. If the main belt goes, it could take out that hose and the replacement belt too. I kept mine in my toolbox.
Just swap out for the top radiator hose for the dual alternator set up like Big Calo says. Hose is like $15 and you can reuse your coolant after you drain it in a clean jug to make the switch.
107.4K members
