I currently have a 2 inch leveling kit on the front and I added a 2 inch block in the back to make the truck level. Turns out its a little to high in the back now and I am trying to find a one inch block to replace it. I can only find a one and a half inch block on the web however.
If anyone knows where I can pick some one inch blocks up or has some one inch blocks they are looking to get rid of let me know. I'd trade my 2" for your 1" as well.
I've got a 3/4 ton. What is the measurement of a 250 block vs a 350 block? I was thinking a 250 block is 2 inches and a 350 block is 4 inches. I currently have a stock 250 block with a 2 inch block stacked on it. I'm looking for just an inch taller than a stock 250.
I would go with a factory F350 block if I was you. If you are in the right place at the right time all it will cost you is some u bolts and maybe not even that.
Well I guess the 350 block is the route I'll go. I shouldn't even need new u-bolts because I've already got longer ones from my two inch block. If anyone has a set of 350 blocks they are looking to get rid of let me know!
Thanks for all your help guys!
