So I did a two inch body lift and now my stick is hitting the floor in L and 2nd. Would a short throw shifter fix this? is there anyone that has this same combination?
LOLLOLLOL How will that help solve the problemoke:LOLLOLLOL
That just struck my funny bone...
To the OP take your boot off and cut the hole were the shifter is a little bigger.. That should help give you more shift room, And cheaper then A shift kit
oh and so I am at least the slightest bit helpful, I did some digging and found a picture of the short shift kit from Tank's 250
While doing the digging some guys talking about the ZF5 kit (I'm assuming they are pretty similar) mentioned that the shifter got kicked up about an inch, maybe that will buy you the room you need or least help out some.
