It is really simple. You take the lower half of the mount and remove your front two seat bolts on the passenger seat, then slide the mount under the seat brackets and put the bolts back in. Then slide the upper half on the mount and lock the pin in. I had it in both my 99 and 08 SD's.
That is the one I have except mine has a removable upper pedestal. That whole vertical shaft and laptop part comes off by simply pulling out on a pin and lifting it off.
