Article No
00-1-6
01/10/00
SUSPENSION - FRONT STABILITY BAR MAY BREAK OFF - VEHICLES BUILT FROM 1/1/1998
FORD:
1999 SUPER DUTY F SERIES
ISSUE
The front stability bracket on the front axle may break off due to impact with a solid object or from fatigue.
ACTION
Install a revised bracket. On vehicles built before 3/21/1999, install a new stability bar bracket which will raise the bar approximately 25 mm (1"). This will reduce the possibility of breakage. Refer to the Service Procedure for details.
PART NUMBER PART NAMEF81Z-5486-DB Mounting BracketN605921-S426 BoltN620482-S427 NutYC3Z-5A316-AA Cap - Front SpringF81Z-5486-AA Retainer - Stability BarF81Z-5484-EC InsulatorFB1Z-5484-JA InsulatorFB1Z-5482-FA Stability BarF81Z-5482-AA Stability BarF81Z-5705-BA U-BoltN805480-S426 Nut
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME000106A Install Revised Stability 1.1 Hr. Bracket And Stability Bar (Super Duty F Series 4X4 Built Prior To 3/21/1999)000106B Install Revised Stability 1.0 Hr. Bracket And Stability Bar (Super Duty F Series 4X4 Built On Or After 3/22/1999)000106C Install Revised Stability 1.6 Hrs. Bracket And Stability Bar (F-450/550 4X2)
DEALER CODING CONDITIONBASIC PART NO. CODE5486 01
OASIS CODES: 303000, 304000, 702100
Stability Bar - Front Bracket May Break Off
Article No
00-1-6
01/10/00
FORD:
ISSUE
ACTION
N605921-S426 Bolt
N620482-S427 Nut
F81Z-5705-BA U-Bolt
N805480-S426 Nut
Built On Or After
3/22/1999)
(F-450/550 4X2)
DEALER CODING
CONDITION
BASIC PART NO. CODE
5486 01
Formated a little better.
