First you got to take it out of the box. Next you would have to walk to your truck and open the door. J/K busting your balls. I'm sure it comes with easy instructions on how to install it. I know my spartan did.
best thing to do is read the instructions BEFORE you start to install anything.
the mini max is easy and you will only have one wire to hook-up unless you want more than one egt gauge.
First figure out where you want to mount it.
Then run the hdmi cable
Then hook the obdII port up and connect the wires (I think it's the purple one with the one from the h&s, and the ground one to some metal on the truck)
Done.
