I recently put the icon 6" lift on my 04 and the rear is low. Is there a good place on the truck front and rear to measure to see how much I need to lift the rear to make it sit level? Are the wheel wells good for that?
I've recently heard people say to check with the front of the bed and the rear of the bed to see if it's the same height.... I know its not the front like you may want to do, but I assume it provides the same effect. I would do that and check the wheel wells if I were you.
I always measure from ground to pinch weld behind front wheel opening and in front of rear wheel opening because the front and rear wheel openings are different.
