i have a 6'' skyjacker lift on my truck. looks B/A but im just sick of jumping in and out. i want to go back to a 2.5'' leveling kit. i had one from Zone on my last truck and really liked the ride i got from it. i didnt lift this truck i have now. i bought it like that. so im wondering what all i would need to do the level job. any help would be great. thanks alot
Same thing as putting it on. Hardest thing will probably be the drop pitman arm. Sometimes U bolts can be rusted on. I traded my stock lift for this 8 " lift and it was a 12 hour non stop day with 3 guys. Pretty easy just time consuming for a day or two.
getting the stock parts seams to be the hardest thing, if you got that you are golden make sure you have f350 rear blocks if you want to do a leveling kit.
where are u located? I would work out a trade with u for your lift, I have several sets of OEM ford springs, I have a leveling kit just came out last week from a 00 f350 w/ plow package. had 101,000 miles.
Ok cool well let me know if you want to work out a deal it will take about 6 hours to swap out, if you dont fine someone or somewhere else to do it, worse case i can sell u some OEM springs ill get u the spring codes just so u know exactly what they are.
Let me tell you how happy you will be. OBSWIZ hooked me up with a front hanger lift, and correctly valved bilstein shocks. V and b code springs I got locally. Truck is pleasant to drive in again!
I believe I got the 3" front hangers, which made the truck sit abou 1/4" rear high.
ok keep in mine I have everything here as far as stock susp. we will need new u bolts, & have to figure out which pitman arm u have 32 or 36 spline. I should have both but ill have to check to be sure.
I have local shop close to me here that will bend up new u bolts while we wait whatever spec we need. Or I can get some from BDS they are about 30 min from my house & a buddy of mine works there so he can bring em home for me.
Haha, I ran 38's with the spring that are going in your truck but they rubbed on the back of the front fender pretty good, Im pretty sure 35's will fit & not rub. If so we can always put another add a leaf in the front pack, I have those to.
107.4K members
