You have to cut the header panel to make them fit. Its not too hard, Ill be doing this over the spring break and putting in some 10000K HID's from retro solutions :evil
The 99-01 and 02-04 lights will slap right in, but you'll need new marker lights aswell. The wiring is all there, just remove the short jumper plug, and it will plug right into your 9007(iirc) bulbs.
If you go to 05+ light then you have more work cut out for you like the post above said.
