Well first off, my truck has 3.73 gears with an open rear diff. Its not bad unless im on snow or something slick and its nothing to start spinning and have to put it in 4wd and even then it doesn't do nearly as well as my old mans truck with a limited slip.
I have a buddy that parting out his '99 which has a 3.73 limited slip with 150k on it. My truck has 147k on it so that seems like a good match in miles. Is there anything i should do to that other axle before i put it in? Tighten up the limited slip or anything? I planned on giving it a fluid change and maybe painting it while its out. I will be picking it up in about 3 weeks probably.
Thanks
Thanks
