Injector torque specs - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 02-19-2011, 03:00 PM
stoker04's Avatar
stoker04
Offline
Member's Gallery
What are the torque specs for the injectors? I want to do this right the first time so any pointers would be very helpful. Also what do you guys torque the oil rail down too?
__________________
2004 F350 6.0 ECSB Lariat. All the normal stuff
Reply With Quote Quick reply to this message Go to the top
Old 02-19-2011, 08:37 PM
cartmanea
Offline
Member's Gallery
Re: Injector torque specs
For the injectors, in '03 the spec was 24 ft-lbs, later they increased it to 26 ft-lbs, and most builders recommend 28 ft-lbs to ensure the copper washer seals well. Make sure the bolt holes are clean and free of oil as this can affect the torque.
The rail bolts are 8 ft-lbs (96 in-lbs) for my '03, and your '04 should be the same. There is a sequence to tighten them in, here's the diagram from my service manual:
Tightening those oil rail bolts made me very nervous, being aluminum, be very sure of your torque wrench accuracy. Also, I just did 26 ft-lbs on the injector bolts, since that was the higher of the two factory specs and I didn't want to break anything. Good luck!
__________________
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
  #3
Old 02-19-2011, 09:47 PM
stoker04's Avatar
stoker04
Offline
Member's Gallery
Thanks a million man! When you torque this oil rail how do you fit your torque wrench on the bottom oil rail bolts, as its a very tight fit.
  #4
Old 02-19-2011, 10:20 PM
cartmanea
Offline
Member's Gallery
Driver or passenger side? I did both, and if I recall I couldn't get the torque wrench in on the lower passenger side so I used a box end wrench and did them by hand, comparing with another bolt I had torqued to about 85% of spec.
  #5
Old 02-19-2011, 10:25 PM
stoker04's Avatar
stoker04
Offline
Member's Gallery
Passenger side
  #6
Old 02-21-2011, 12:27 AM
stoker04's Avatar
stoker04
Offline
Member's Gallery
Also I heard that Vaseline can be used for the injector o-rings and injector body? Should I clean out the Injector bore too?
  #7
Old 02-21-2011, 12:31 AM
cartmanea
Offline
Member's Gallery
I didn't bother cleaning out the injector bores, I was concerned about knocking pieces of crap loose in there that could interfere with a seal, so unless you have the cleaning brushes and do it really well I wouldn't do it. Most builders use clean engine oil or ATF to lube the new o-rings, I used clean motor oil.
  #8
Old 02-21-2011, 12:34 AM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Send a message via AIM to CTC DEEZUL
wow... not cleaning injectors cups has to be one of the stupidest things I have ever heard....
__________________
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
  #9
Old 02-21-2011, 12:40 AM
stoker04's Avatar
stoker04
Offline
Member's Gallery
Do they make a special brush for that?
  #10
Old 02-21-2011, 12:52 AM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Not that I know of. I have smaller wire brushes that I put into a drill bit extention that goes into m 90 degree angle grinder. I put it odwn there, give it a few turns, spray some BG carbon cleana nd wipe it clean with rag and screwdriver. Than I either use my Blue-Point vacuum and suck the cyliner or blow it out with blowgun... Usually both. I then take snap-on camera down bores to make sure we all good... and pick up some STP Oil Treatment... Its thick as #### and it great for seals
Human Verification
(View-All Members who have read this thread : 176
02POWERSTROKE7.3, 03RaptorCV, 04 f350, 04stroker, 06-6.0 stoker, 06regcab6.0, 07_powerstroke, 08twinturbo, 1craneguy, 2003ford, 250stroke, 440wagonr/t, 5954cc, 6speedSD, 7.3-6.0-6.4, 78f100, 92f150300six, ablank, bad moose, BDS, BigDeal21, BigE, BigJake, bismic1, bluemountianpowerstroke60, blwnmstgt1990, boost4life, boosted93cobra, BootZ0360, broncoformudv, Browning, BullsEye, bustednuckles, Carry Big Stick, cartmanea, Cass, charlez, cheprice, Chuggins10, clint2309, co04cobra, CTC DEEZUL, Dangyo, Dave0560, Davepomrenke, demented_diesel, dexleo2, Dieselboy, DieselFreak92, dieselmac, dieselman64, Dirt Floor Poor, DLinzy, DReese, Duceswild, dwall, DZL JIM, ecraig, EMC Van, eyoung, f-150_xl, fdny136, Fever, fireanchrome, firemudder, floridastroke, FTAJ, fuekear, FX4 F2-Fifty, gabelivingston, gary brumley, Gibrid4x4, gonegreen, Grandmaspeedshop, greenbeast, groovelow, harleyf250, hawgdoctor, Heavyhaul, hill_billiez, hornythrony, hoss869, J HO 22, JAKE, jasensmith, JD F350, Jgman141, jim dandy, jjflores08, Joeys199, Johnboy3, Joshs4x4toyz, KBROOKS, kraiger, lazlow, LBCpowerstroke, Lildiup, LILGSX, lincolnlocker, loughnan, lubeowner, markfuga, matthewd11, middlemanjw, miller45103, mjcolemn, Modern90, Monstar, NickHilbert, NoBallz, Nodge, nrook, obs stroker, old Smokey, oldwood, Oscar1017, outlaw 4017, paranoidredneck, Petro, pjwoolw, podirtfarmer, power strokin, Powerstroke Racer, powerstroke02, powerstrokemaison, Pwnm30rdi3, Rcmx88, rdunagan, repoman54r, ricpowel, RW_Kaspar, S04X, SamW, scparrish, SD_PowerStroker, Seventy468, shamrock442, Shaw, smitty403, SmokinBlueOval, snopro_03, SootRoller, spindrift, squig_2000, Stacks92, stoker04, stoneykegonsa, stroke of luck, stroked, stroked99_1/2, strokeorcroak, StrokeThis34, strokingkid1392, suprdzlduty, svilla, svt28640, TAMU_PSD, texans, Texas Limo, TexasStroke01, theSLEEPER, toolmangary, treetechsixOH, Trouth302, turboculosis, turbodiesel_02, twelch3, twoicebergs, TX_S, tyler886, webb06, whytry, wicked_four_play, wyoradcat
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
