6.0 oil leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 02-17-2011, 04:15 PM
BIGDUX
Offline
Member's Gallery
6.0 oil leak
I have a small oil leak <occasional drip> on my '05 6.0. Seems to be coming from top rear of engine. Leaking off oil pan, front of bell housing, and starter. Appears to be more prevalent twd passenger side of engine. Any ideas?
Thanks
Reply With Quote Quick reply to this message Go to the top
Old 02-17-2011, 04:24 PM
DieselStroke's Avatar
DieselStroke
Offline
Member's Gallery
Re: 6.0 oil leak
This might sound stupid, but are you sure it is oil and not coolant, soak it up in a paper towel and check the color of it, most likely it is coolant, in this case it would be your connector between oil cooler and EGR cooler, let us know, if it is indeed oil im not sure where it could be coming from.
__________________
2004 F-350 SC LB 4x4
6spd manual transmission
Edge Juice w/attitude
Scangauge II by Linear Logic
Straight pipe exhaust
Westin Bull Bar
Lights
  #3
Old 02-17-2011, 05:48 PM
HeavyAssault's Avatar
HeavyAssault
Offline
PursuitInterceptor
Member's Gallery
Re: 6.0 oil leak
Is it leaving a puddle under the truck?
__________________
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
  #4
Old 02-18-2011, 12:04 PM
ktmrydr686
Offline
Member's Gallery
Re: 6.0 oil leak
possible turbo drain line?
__________________
04 f250 4" turbo back gauges diy coolant filter
  #5
Old 02-18-2011, 01:57 PM
lenzhotrod
Offline
Member's Gallery
Re: 6.0 oil leak
Could be almost anything. Mine was the turbo drain. Test,verify,repair.
  #6
Old 02-19-2011, 02:19 AM
browtine
Offline
Member's Gallery
Re: 6.0 oil leak
mine leaks in the same spot. Just barely damp underneath with a droplet or 2.... coming off of starter. Might leave a spot the size of a quarter after a few days of sitting? I cleaned mine up really well and then re-diagnosed and mine is the glow plugs leaking. Evidently the glow plugs run thru an oil passage or something? I haven't fixed yet but that's what it looks like and I discussed it with someone on here a few months ago and that's what I found if its any help....
__________________
-Ryan
2004 CC SB 6.0L, T/S, red, FX4, XLT, Autometer GS Pyro and boost gauges. SCT Xcal2...tunes from Matt @ Gearhead Automotive
  #7
Old 02-19-2011, 02:23 AM
truckshop
Offline
Member's Gallery
Re: 6.0 oil leak
i work at a dealer and haveseen many bedplates leaking sounds like what your talking about. clean the engine off real good with brake cleaner and check after driving it about 15-20 miles. good luck
  #8
Old 02-23-2011, 10:49 PM
BIGDUX
Offline
Member's Gallery
Re: 6.0 oil leak
Thanks guys. It is not leaving a puddle. If I wipe it off once a week, you hardly know it's leaking.
  #9
Old 02-23-2011, 10:51 PM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Send a message via AIM to CTC DEEZUL
Re: 6.0 oil leak
inspect oil psi sending unit
__________________
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
  #10
Old 02-24-2011, 12:31 AM
zx800x's Avatar
zx800x
Offline
Diesel Sled Head
Member's Gallery
Re: 6.0 oil leak
Check your hot side intercooler boot off the turbo. I have seen many of them seep just enough to leave a drip or two every now and then
__________________
2001 f250 H2E,BTS,Stealth,reg return,mod IDM, spearco,DI Ceramic Headers.. bcode stage 3's Cale's Tunes
Human Verification
(View-All Members who have read this thread : 251
03-blue-Powerstroke, 03F250 6.0, 0460psd, 04La4iat, 04stroker, 05lariat, 06 f250 man, 06F350-63863, 07_powerstroke, 1snowcat, 2 Power, 2005stroker, 2006powerleaker, 2ndHandSmoke, 4diggn, 6.0Pwrstroke, 6diesel6fuel6only, 86F250, 94 tpr, afFORDable, Agjake11, AGV2006PSD, alliancediesel, amdriven2liv, Arctic Fox, bad moose, Barnbuilder, BBowden73, BCS, bennyboy, benscott08, big deal, BigBlack03, bigdaddy60, BigDeal21, BIGDUX, Bigfordguy07, bighorn3, bismic1, BlAcKeNeD, bluovldeezl, boatfixerkenn, boboznutz, BPR83, browtine, bustednuckles, cadwell08, calvinjwilcox, Cam45, captkeigles, cavscout075, charlez, Chuck550HD, CLAC, clp13294, cook03F250, Cordwood, cory99, CT SMOKER, CTC DEEZUL, Darkhorse, Dawgfan52, Dbore, ddillenger, dennisr_f350, DEVAST8R, DieselStroke, Dirty outlaw, Dirtyryder, drago1217, duece, dunatic, durafish, Dustin F2504x4, dwall, eatoncobra04, elwood blooz, eviljarv, Evolution905, Extended Power, F-250-Owner, F-25000, F250IT, Falls250, Fever, firebolt12r, FirehouseFord, flashawk, flightmeck, florida 6.0, FMCPowerstroker, fmrdieseltech, fobar22, Force2354, FTAJ, fvrpowerstroke, george german, GRKNCK73, Gummy, gwskulls, hawgdoctor, HeavyAssault, hill_billiez, Hobo-Stew, huck2080, hydesert1, id: 5520, Ignorant1, indiana lineman, Jbstroker87, JD F350, jdi731, je5689, JEBassler, Jeff M, JerDirte', jerry k, Jgman141, jimhall_az, jl250sd, jmsmith76, joelykool, johnsdeere, jorris83, jratoms, JS98, jtaylor75, JustEZNAlong, Justin6.0, jzamluk, Kdavid1, kenny7231, king06, KingRanchSick.0, Kitch, KONADOG, Krisco, ktmrydr686, KyleK, legionxxii, Low Key, Luke101979, majek5, MarkEB250, markt, matthewd11, meandog06, medicman88, mike b, Mike T, Ministry, Modern90, Motownfire, mouse, Mpoage, mra4x4, muddy650, mudworld, Mustangl3, mwaltersaleen, mx185sw, necks00, new2deisel, New6.0PSOwner, nitrouskid2601, NMPSK, nos487, nrook, NYC F-350, o4ep3civ, oldwarrier, orrwhat, pa-powerstroke, paranoidredneck, Paul Adkins, pc97f350, pccurr, pedtech, pjerrn, plumber dave, powerstrokeboi_06, PowerSub, pstahl, quicksilver, RAUD, Realdealoo8, ringmaster66, RiverRat, Rob D, Robbobchuckboheman, RobSpook, romad99, saleen398, SaNnDnSurF, sb-one, Schuls, seeemmiss, semmens21, sg465, Shef, ShiftyCapone, shreyshah1120, skippy, sleeper_sicksoh, sly1types, slyfly76, snagalittle, sobek11367, sonnyy13n, SouthFlstrokin', spazelin, srxsteve, STAX, Steve'O, stewman, Sti470, stoke17, str8wkd, stroke of luck, stroked, stroker62, StrokeThis34, sunsetmazdacs, superdooty89, tchain, techteacher, TexasStroke01, thathoustonkid, The Gray Mule, Tinbender, toolmangary, towin stroker, truckshop, Turbodiesel6.0, twhetten, TXBammer27, tyler886, utripin, Weatherlite, webb06, Weefarms.americandiesel, welfordnremt, whiterp199, Willem, wiltface, wyoradcat, Zane-03 King Ranch, zeekzimm85, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
