I replaced the bad valve cover gasket and the uvch, with absolutley no change to the way it runs, it still sounds like ####
So this evening i borrow my buddys scanner and i run another buzz test it says it passed the test, but i noticed almost all cylinders sound a little bit different, the 7th one to buzz sounds the worst, but it passes the test:blah:
So i run a cylinder contribution test, it seems to run better sometimes in the test then normalWTF? ok well after listening for 4 minutes to it make it miss worse or run better it passes that test too ok im furious now it has a test that it does running that gives data, but i dont know that all the numbers and abbreviations mean only thing i could figure out about that test was my engine speed varies from 580-670 rpm,
Last thing i ran the injector test more than once, the first time it said cylinder 1-3-7 had an open circuit. then all the other times it said pass, wth is going on here
