Pros and cons of disconecting the EBPS....... - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 04-16-2008, 03:24 AM
64pcode
Offline
Member's Gallery
I know this has been covered befor and i searched the forum far and wide about it. Can someone please list the pros and cons about unpluging the EBPS. So far what ive got is when unpluged the back EBPS is openat all times, correct? What are the benifits to it being open as to being closed? And it will make my truck sound like the starship enterprise at all times, correct? I just dont want to damage anything, or hurt performance. O and can someone please tell me where it is, i read its under the turbo and i cannot fit my hands in there to save my life.
__________________
02' F350 Crew Cab all stock.........For now.
Reply With Quote Quick reply to this message Go to the top
Old 04-16-2008, 03:56 AM
Pocket
Offline
<-- it's like that
Member's Gallery
Re: Pros and cons of disconecting the EBPS.......
The EBPS (exhaust backpressure sensor) sits on the front of the motor, and reads exhaust backpressure via a tube from the passenger's side manifold. Completely disconnecting the sensor such as unplugging the wiring harness will cause the SES light to illuminate, and the EBPV (exhaust backpressure valve) to disable. Meaning the valve will always stay open (no more hissing noise in cold weather while idling). Also there is debate on how much effect it may have on fueling tables. So by disconnecting it, there is a possibility of you actually robbing yourself of some horsepower.
General consensus is to leave it plugged in. If you want to disconnect the EBPV and prevent it from closing off, then you would unplug the electrical connector at the actuator, which is located on the front of the turbo pedistal, way under the turbo in a very inconvenient and hard to reach spot. But, once that plug is unhooked, the EBPV will remain open, and unplugging that connector will not set the SES light or interfere with any engine management systems. Now you still have a functioning EBPS, but a disabled EBPV.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the Colorado diesel community.
  #3
Old 04-16-2008, 04:00 AM
StrokerTurbo7.3's Avatar
StrokerTurbo7.3
Offline
<----Simply the best.
Member's Gallery
Send a message via AIM to StrokerTurbo7.3
__________________
No longer a proud member of PSN.
  #4
Old 04-16-2008, 04:15 AM
64pcode
Offline
Member's Gallery
I think i will just leave it hooked up then. Thanks for the info. Fred.
  #5
Old 04-16-2008, 04:19 AM
moose99ps's Avatar
moose99ps
Offline
Member's Gallery
i disagree... mines broke and just laying there.. no SES here and half the time those tubes are blocked up with soot neways
__________________
early 99, xcab, 8"lift,37" toyo open country m/ts, afe stage II,BDP tuning, 5" black chrome aussie cuts, blacked out bumper and grill, 8 isspro performax guages, stealth dual pumps, a few fuel leaks......
mods to come:
NO SACRIFICE..... NO VICTORY!
  #6
Old 04-16-2008, 01:24 PM
Pocket
Offline
<-- it's like that
Member's Gallery
I guess there's a difference then between these trucks because mine will set the SES light if I disconnect the wiring harness for the EBPS.
As for the fueling issue, I mentioned it's debatable. I to have "disabled" my EBPS by removing it from the tube, and capping the end of the sensor and plugging the tube off. The electrical connector is still hooked to the sensor, but the sensor is not reading anything but ambient pressure. With it hooked up this way, I never noticed a difference in power. I did try it unplugged before removing and capping it off, but that SES light was annoying.
  #7
Old 04-16-2008, 02:14 PM
Doakster's Avatar
Doakster
Offline
Member's Gallery
As far as the CEL light, when having my PCM scan a while back, there was actually a EBP sensor code in the PCM but no CEL light was illuminated. I went ahead and replace the EBP sensor and tube anyway. Long story short it may or may not throw a CEL, I've heard threw the grape vine that Jody recommends keeping it connected and functioning properly, and we all know his word is the law, wright?
__________________
2003 F-350 4x4 SC 7.3, WOP QSSB Turbo, Isspro Gauges, MBRP 4 inch, AFE Stage II, , DP Tuned Stock, HI, 40t, 60t, 80t, 80e, 120R, 140ex, 6.0 Trans Cooler, 08 Tow Mirrors, 35in Kumho Mts
1993 International 4600 Dump, 7.3 IDI
  #8
Old 04-17-2008, 12:53 AM
DIRTBIKEZ
Offline
Member's Gallery
My early 99 would not set the SES light with the EBPS disconnected either. Like I said it was much easier to reach being in the front of the motor as I would connect it and disconnect it as needed during the winter.
__________________
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
  #9
Old 04-17-2008, 02:22 AM
Cool Canuck's Avatar
Cool Canuck
Offline
Above It All
Member's Gallery
Disconnecting the sensor in my '01 does not set the SEL. I also think this is the better option. The PCM will keep the valve open. If you unplug the actuator, the PCM loses control. When you start the truck, the PCM normally exercises the valve. I don't know for sure, but this may still happen with the sensor unplugged. (that would be a good thing) Of course that would be impossible with the actuator unplugged.
__________________
'01 F250 SC/SB 4X4 Trailer Tug
  #10
Old 04-17-2008, 03:22 AM
Pocket
Offline
<-- it's like that
Member's Gallery
When you unplug the electrical connector at the actuator, it completely disables it from closing. It will always remain open, and will not cycle closed at any time.
  #11
Old 04-17-2008, 03:34 AM
StrokerTurbo7.3
Offline
Member's Gallery
I havent seen any CEL or anything appear and I have had mine unplugged for 2 months maybe now.
  #12
Old 04-17-2008, 03:52 AM
Dieselgeek's Avatar
Dieselgeek
Offline
Member's Gallery
Mine is laying in the valley along with some dried up blood off the knuckles...
__________________
2002 F350 Reg Cab,4x4,7.3,6Spd.
  #13
Old 04-17-2008, 03:54 AM
StrokerTurbo7.3
Offline
Member's Gallery
knuckle busters...my favorite
  #14
Old 04-21-2008, 12:49 AM
fiveohpatrol
Offline
Member's Gallery
Just thought I'd share that mine set off the SES light (2000 excursion) when I unplugged it under the turbo.
  #15
Old 04-21-2008, 12:57 AM
IH_deere_slayer's Avatar
IH_deere_slayer
Offline
Member's Gallery
i took the whole butterfly valve out im pretty sure its not going to close on me running 60 down the highway anymore lol
__________________
2011 3500 HD Duramax
2006 T800 KW Daycab ISX Cummins
  #16
Old 04-21-2008, 04:23 AM
StrokerTurbo7.3
Offline
Member's Gallery
Ellettsville, IN
Where is that exactly in Indiana??
  #17
Old 04-21-2008, 05:27 PM
big_stroker's Avatar
big_stroker
Offline
The Fireman
Member's Gallery
Originally Posted by StrokerTurbo7.3 View Post
Ellettsville, IN
I'm thinking its north west of Bloomington
__________________
Dynoed 520hp and 926tq on 5/23/09
Dynoed 516 hp and 1121 tq on 4/24/10
  #18
Old 04-21-2008, 08:40 PM
aklim's Avatar
aklim
Offline
Member's Gallery
Go to www.spdiesel.com and see their Other/New Products tab. There is something that keeps the PCM happy when you unplug the EBPS and another one for the EBPV. I am keeping my EBPS and ditching the EBPV so I am getting the pug for that one.
__________________
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
  #19
Old 04-21-2008, 09:04 PM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
Just unplug it, if it sets a code call Garrett at http://www.puredieselpower.com he sells a code fooler for it.
Trust me you won't miss it.
__________________
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Human Verification
(View-All Members who have read this thread : 155
1highstroke, 1snotrocket, 64pcode, 806bob, 96'BigBlue, 96centurion, 997.3PSD, 99F250Smitty, airflo71, aklim, AMB, Arisley, Barnbuilder, Beefmansauce, bens99f350, Bigdog, bigfastford, Bigtimearcher, big_stroker, black01exc7.3, BlackPearl03, BMac, bobbarry, Boomer, BRAVO, Breacher, brickhead, Bushwakd, Calico5, CamTom12, cat45, CATdiezel, clayc_989, clydesdale, ColbyPs, Cool Canuck, cota, crowz, CSIPSD, CT8, dbcampbell, DChalue413, Deputydog, DIEEEZELLL GIRL, Dieselfever, Dieselgeek, DIRTBIKEZ, dirtybooz16, ditch_dawg, dlonno, Doakster, Dr. Dezel, driverturbo, e444, efilnikufesin, F350 FF, fbilly420, FireFixer, fishslayer, fiveohpatrol, fordboy424, garyharrin, godofdew11, gosperformance, Got Diesel, gpeyton, haulin99sdp, hawkeye, helvis, icamess, IH_deere_slayer, Insaneba, ironworker25, jakef250, Jaymav3000, JHill, jlegg, joediesle, Johnny77Mutt, josesimoes2, KAC1023, KMurakami, kyle575, LaJ10, Layson, LeRoi, lightsOUT, losfinch, Luke909, maddzack, Martin #6, mattrac, mech2161, metalphd, MidTNStroke, Miffsudd, moose99ps, Morning wood, Mr. Bob, mustang_gt_350, mx185sw, nchappy, NEVRNF, northid710, Not4show, npen, offroad_diesel, PeterB, Pipewhiner, Pocket, powerstroke1979, powerstrokinit, pullths, racehauler, RacerPuller, RallyGTI, Ramblin'_Man, Redfish, Riley250, rob10970, Rockcrusher, rocketron, rpm-inc, Sanger, shaddaddi, Shep, shopteacherguy, SickFord, sixiron, slick_fork, southbend_powerstroke, southmike, sparksmx450, sslong, StrokerTurbo7.3, SUPERDF350, theSLEEPER, tkdbf350, Torque37, toypuller, Traci, TxFire, urbandiesel, urbanwheeler, voodoomaker, wfodiesel, wrench junky, Wyo, yamt03
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
