Tries but no start. New ipr, new icp, NO CODES. - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 02-10-2011, 09:26 PM
joostmee
Offline
Member's Gallery
Exclamation Tries but no start. New ipr, new icp, NO CODES.
2003 f-350, strong batteries, 300k miles, no codes, no start.
The truck died the other day, and wouldn't start. For a couple of weeks it has been hard to start. I replaced the icp because oil was leaking down the back of the engine, and it fired right up.
The truck ran for two days after the new icp, then died the same way. Won't start. I put voltage to the ipr and still nothing so we replaced the ipr. When the old ipr came out the screen was GONE!
After replacing the ipr the truck still doesn't start. I pulled the ficm and noticed that the connectors were loose, and will no longer clip, so i have to push them into place and have someone fire the truck. Still no start, but now it tries to start.
Anyone have an idea what this might be. I plan to do the ficm test this evening, and take the voltage of the icp. I checked for codes and found nothing.
Reply With Quote Quick reply to this message Go to the top
Old 02-10-2011, 09:29 PM
zx800x's Avatar
zx800x
Offline
Diesel Sled Head
Member's Gallery
Re: Tries but no start. New ipr, new icp, NO CODES.
Did you remove the part of the screen that was missing from the IPR?? The screen gets stuck and the plastic retainer also. Need to be removed before installing the new IPR. May have HP oil leak in the engine.
__________________
2001 f250 H2E,BTS,Stealth,reg return,mod IDM, spearco,DI Ceramic Headers.. bcode stage 3's Cale's Tunes
  #3
Old 02-10-2011, 09:45 PM
joostmee
Offline
Member's Gallery
OMG no i didn't remove the screen. Stuck my finger in there and assumed it was gone...
  #4
Old 02-10-2011, 10:40 PM
BCPSD's Avatar
BCPSD
Offline
Member's Gallery
HPOP maybe. Symptoms are about right.
__________________
06 6.0 Powerstroke Crew Cab
S&B Intake
MBRP exhaust
Powermax
TSD tunes
  #5
Old 02-11-2011, 12:24 AM
lenzhotrod
Offline
Member's Gallery
no start/hard start
Try these.
Attachment 19904
Attachment 19905
  #6
Old 02-11-2011, 02:41 AM
joostmee
Offline
Member's Gallery
Ok i removed the screen from the original ipr, and reinstalled the new ipr. Almost fired up once but nothing now.
Prior to this when i held the ficm connectors in while someone starts the truck, i had to put a lot of pressure on them before the injectors cycled or the truck tried to start.
  #7
Old 02-11-2011, 02:50 AM
joostmee
Offline
Member's Gallery
Thanks for pointing that out zx800x! I would have been troubleshooting forever before i found that.... now if i can only get it to run.
Also thanks for the links Lenzhotrod.
  #8
Old 02-11-2011, 03:05 AM
joostmee
Offline
Member's Gallery
BTW I still don't have any codes...
  #9
Old 02-12-2011, 06:23 AM
joostmee
Offline
Member's Gallery
Ok. Turns out that the turbo y pipe was cracked and the injector harness was pretty scorched. New y pipe, new harness, no codes and the truck still won't start. Any deas?
I have +48v at the ficm, and ill be testing the voltage at the icp first thing in he morning. I was able to get the truck to start by moving the ficm harnesses.(at least it seemed like thats what caused it to start.) But I couldn't ft the same results except it tries to start...
  #10
Old 02-12-2011, 10:34 AM
bismic1
Online
Member's Gallery
Did you hear the FICM connectors "click" when you re-installed them? It takes quite a bit of force to get them in all the way.
When you test FICM voltage, it needs to be at KOEO, cranking, and at 2000 rpms (if possible).
__________________
Mark
Human Verification
(View-All Members who have read this thread : 78
06F350-63863, 07f450, 123rday68, 2006.1f250, 2BIG, acasey7.3, bad moose, BCPSD, bigbeariron, bigdaddy4x, Bigdog, bismic1, Black&Gold, BPR83, browtine, bubba33003, buc1096, bustednuckles, candbauto, caveman1, Codydiesel, coldhanz, coysdieselspecialties, draggnash, evil 04, F350R, Fever, florida 6.0, Fro_911, gaf350, ghostrw, Goose, hill_billiez, infantry032003, irontx25, jackstraw212, jbarlow15, jdc753, Jeremy, jmsmith76, joostmee, ju015dd, jzamluk, ktmrydr686, Low Key, lubeowner, lynger, machete31, Matt07, middlemanjw, Monstar, myronbilliot, nickersonf350, nvme_63, nylyon, ol'white027.3, pjerrn, Realdealoo8, RRF985, sga6.0l, shocka04, silent64, silvernblack6.0, steinerr, stoker04, stroke931, strokethis05, Strokin304, toolmangary, tyler886, uga33, upinsmoke70, vanderchevy18, yeehaw, Zmann, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
