EGR Delete - Pros/Cons What say you? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke - Aftermarket & Performance
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto Escrow
Thread Tools Display Modes
  #1
Old 01-29-2011, 01:45 PM
NIX350's Avatar
NIX350
Offline
NIX-350
Member's Gallery
I know there are several threads on this but... I recently was in the "FORD" service department for an oil change. Since the pick-up is new to me, I asked that they give it a quick look-over while doing the oil change. Having looked it over extensivly myself along with others I was and am confident that it is solid. When the service manager came out he said "you have or will have a head gasket leak". Now, I immediatly said to myself !@#$.... I asked why he said this and he replide that there was a bit of residue on the overflow tank. I know I had some spray when I took the cap off a bit warm...so...other than that, no signs...no leaking, no overheating, no fluid level changes etc.... I'm very interested in the delete kit, but want to know if that's a good thing or bad???? AND, what kind seems to work best...the guy thats looking to install says I don't have bad gaskets but that the EGR is probably looking to go and he installs Sinister...I've read great things about Bulletproof too - any thoughts on brand??
Reply With Quote Quick reply to this message Go to the top
Old 01-29-2011, 01:51 PM
offroadinginaz's Avatar
offroadinginaz
Offline
It wasn't me
Member's Gallery
Re: EGR Delete - Pros/Cons What say you?
Bullet Proof is a proven EGR cooler. There are a ton of people using them. With a lifetime warranty you can't go wrong. Make sure you replace your oil cooler while the truck is apart.
__________________
Newman
A few Fords
Special Thanks to:
Bullet Proof Diesel
Strictly Diesel
Arizona Powerstroke Group
  #3
Old 01-29-2011, 01:56 PM
NIX350's Avatar
NIX350
Offline
NIX-350
Member's Gallery
I guess that's the second part to all this...is it better to replace the "stock" failing system/cooler...or to go with a Delete kit.
  #4
Old 01-29-2011, 01:59 PM
offroadinginaz
Offline
It wasn't me
Member's Gallery
Any way you look at it your oil cooler is probably bad. The EGR cooler is just the messenger. If you delete the messenger and don't take other precautions you'll end up with a bad engine do to extreme oil temps.
  #5
Old 01-29-2011, 02:03 PM
offroadinginaz
Offline
It wasn't me
Member's Gallery
Clicky!
  #6
Old 01-29-2011, 04:18 PM
pizza pig's Avatar
pizza pig
Offline
i like to party
Member's Gallery
exactly, get something to monitor your Engine oil temps (EOT) and engine coolant temps (ECT)
At cruising highway speeds they should not have a delta greater than 15* or so...
If there is gap greater than 15* than its time to replace some parts. What parts?
- Oil cooler
- Delete the EGR
- Coolant Filter
- ELC coolant flush
The Ford gold coolant breaks down its silicates under high heat and creates a goo. This goo clogs up the oil cooler and blocks coolant flow. This blockage of coolant flow prevents the EGR cooler from getting coolant to cool the exhaust gasses. It therefore ruptures and allows coolant into the combustion chamber lifting the heads and popping head gaskets.
EGR delete is 100% better than upgrading the cooler to a Bullet Proof Diesel one.
ELC is silicate free and is what should be in these trucks from the start. A coolant filter catches castings sands from the block and further prevents the oil cooler from being clogged up.
  #7
Old 01-29-2011, 11:41 PM
Sniper32's Avatar
Sniper32
Offline
That Guy
Member's Gallery
i would do a EGR delete, coolant flush with CAT ELC (red), and install a coolant filter. after that youll be good to go
__________________
If You Aint Infantry You Aint Chit!
04 250 cc/sb - ARP, Toyo, Procomp, Sinister, Innovative, PHP, Edge, Isspro, etc
  #8
Old 01-30-2011, 01:10 AM
pizza pig's Avatar
pizza pig
Offline
i like to party
Member's Gallery
agreed, after a friend of mines situation with BPD i would never recommend them again.
  #9
Old 01-31-2011, 05:56 PM
powerstrokedkid87's Avatar
powerstrokedkid87
Offline
Member's Gallery
i agree with most in this thread...pros of doing mods like EGR delete, Coolant flush...coolant filter kit.....oil cooler rebuild: replacing these things is going to help prevent future problems ( i say prevent because regualar maintenance is still needed) through in a set of head gaskets, studs, and a tuner and you got yourself a sick ride......Cons: You will have to be ok with the fact that you will now have a reliable truck that will run strong for years/miles to come......
  #10
Old 01-31-2011, 06:01 PM
strokin6L's Avatar
strokin6L
Offline
Member's Gallery
there is nothing wrong with the gold coolant
__________________
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
Human Verification
(View-All Members who have read this thread : 280
!!!PainTrain!!!, "THE DEMIZE", 04harley250, 04La4iat, 07_powerstroke, 0SICKS0, 123rday68, 1995f350, 19_A_LT, 1BadOutlaw, 2006Duty, 2006powerleaker, 2BIG, 379cat, 6.0Pwrstroke, 60POWERSTROKE73, 6keeper, 7.3Stroker96, 8295jones, Abbott, acey, ajordan193, allstarsixo, alwil, Andy's 250, ApachePilot64, Arctic Fox, ARS267, AXELRICK, bad moose, Barnbuilder, barrett6.0, bassanglerbob, Bayak, bboteler, BBowden73, BCPSD, BCS, Beans71086, Big K, bigbadford01, bigblueford, bigbrdf250, BigDeal21, Binderpower, BINGS6.0, BISQUIK390, black7.3, BlackPearl03, blackranch, boosted93cobra, Boywonder, BrianC, buc1096, buck kyser, buddy357, c2d2013, captainharley6.0, chris-rector, cjetcat, cjvmboricua08, cking1209, coldhanz, colonyofdrones, Constantfix, Cool Canuck, Corcelius, Craig@MPD, Cutting-Edge Diesel, Cuttintracks82, D.F.A., darklcdfeller, Daryl, dbarnett42, dcsnowman169, ddbck, deisel 04 X, Denny B, Deno1300, Detailsunlimited, Devilstang93, dexleo2, dieselfab67, Dieselholic, dieselmac, Diesel_Dan, dirtydieselsixoh, Dirtyryder, dissentary, dpski, duece, dwc032, EPDP99, Erle385, Extended Power, EZ-E, Fever, FLY-GUY, fmrdieseltech, Ford4Eva, ford7.3sd, fordboy11, Fordfreak4life, Frank'daTank, Frtdrmrose7, fuekear, FX4 F2-Fifty, gjoski515, GMAN1, gtmustang00, GTOKILLER, Happy Camper, harley-kid, Harry Nadz, Hidalgo32, HiVoltage, House, huck2080, ibestrokin97, id: 5520, irontx25, isimar, jamcconnell2, jbarlow15, JD F350, Jdevous, je5689, Jeff Severe, JerseyJim, jg6.0, jhaddox, jhiggy94, jmkeck, jobsi, Johnboy3, jonnydiesel, jonnysteals, jprod, jranch, jratoms, JS98, JustEZNAlong, kdsf350, kenny7231, kfletcher, Khemosabe, Kountryboy 6.0, Krisco, krwlntj, kxriderforlife, KYmxracer52, lah2420, LBF, LILGSX, Luther's 2008, LVstroker, MADMAN36, MahdeyS, majek5, maninspokane, maps, marcosmats, markm, mbruce, MColeman, McStroker, metalnova, MHJ, mmangino, montana6.0, Motownfire, motoxracer42, Mpoage, muddynoll, nastys6.0, Natos, Nelly87, nickPSD, NIX350, NorCal997.3, nos487, offroadinginaz, offroadjack, oh8three50, Oilfield44, okiebindernut, Ole, orrwhat, OuchThatHurt, ozoneburner, phoenixrhino2, pizza pig, Powerstroke526, powerstroke742008, powerstrokedkid87, PowerstrokeR00, psduser1, radarweaver, ramkiller97, redjet, REDSOX2758, rgullett83, RIGROCKET, Rmartin-97, rob1232, RobsF350, rodrocket, rugbymachine, Ryledup, SAYIWONT, scst1719, semmens21, sethc24, shadow6.0, shanev10, shocka04, shreyshah1120, SickStroke6.0, silverbullet4x4, Sins4u33, Skintback, skippy, skydude89, SLAMDS10, slick_fork, slosvt, smokeem, smokeless, smokerstroker, Snake, Sniper32, snoblade82, Snox49x, socoman1988, SootRoller, Sprman, STAX, steel, STK97PSD, Stlyidklr, Stroken7.3, stroker57, stroker_1999, strokethis05, Strokin304, strokin6L, strokingkid1392, Superduty9669, SUPERIOR OFFROAD INC., svorob, swaan, swinsen, T SCHMIDT, TAMU_PSD, Taylor.McGovern, Thunderheader, tmars51, tnadanzig, tnmoose, Tom's 2006 F250, topshelf7.3l, TorqueMasterG, travis6363, TTguy, TVMC, tzell2010, UNBROKEN, Viking, wetnsloppy4x, wezol5484, Wff250, whytry, Willem, windrunner408, wvpowerstroke, xrxmxcx, xsperf, yeehaw, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
